Installed Lexus CT200h 17" wheels and 205/50/17 tires
Discussion in 'Gen 3 Prius Accessories and Modifications' started by F8L, Sep 18, 2012.
  1. xcuter
    xcuter Active Member
    303
    182
    I got mine from eBay. I got the cakes from the gen II prius. Perfect fit but they are shiny. [​IMG]
    http://pages.ebay.com/motors/link/?nav=item.view&id=190861941059
    SPH-L900 ? 2
  2. The Critic
    The Critic Resident Critic
    3,193
    2,330
    CA
    Thanks. I think I may go for a look that is more similar to the current Lexus caps. Would you happen to know if the holes are 2.25" wide?
    Nope.
  3. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    673
    179
    Vancouver, WA
    I would love a set of those wheels for my 09 Corolla. :)
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Looks good.
    I used center caps from the Gen2 Prii
  5. The Critic
    3,193
    2,330
    CA
    Thanks Sean. I'll look into those.
    Here's a quick idea of the MPG in case anyone is wondering.
    CT200H with Michelin Primacy MXM4 tires (9/32" tread depth)
    35 psi all-around.
    Ambient Temps: 70-75F.
    A/C at Auto and 70F.
    Speed: 70-75 mph, cruise control whenever possible.
    Trip: Gilroy, CA to Pleasanton, CA fairgrounds.
    Trip MPG: 46.0 mpg.
    If this trip had been made with the 15" Energy Saver A/S, I would have expected 50-51 mpg.
  6. 510bg
    510bg Member
    142
    Are you on stock suspension? How does the car drive stock rims vs 17's?
  7. The Critic
    3,193
    2,330
    CA
    Yes, stock suspension. The front struts have about 70k on them and are fairly worn, so some of the bounciness is probably due to the struts. The straight line stability and traction are much improved. Ride comfort is probably 30% worse.
    iPhone ?
  8. Eric Henley
    Eric Henley Junior Member
    60
    Must say I like f8l's tire size the best if car isn't lowered... It really fits the wheel well...
    On that note i know 50's are rated .5 inch taller that then 45's... It may be a dumb question but does this raise vehicle by .5 of an inch or does the side wall or suspension play a factor in actual height?
  9. The Critic
    3,193
    2,330
    CA
    I would really advise against the 205/50-17 size as most professional tire shops will refuse to touch the vehicle due to the incorrect tire fitment. The 215/45-17 size already presents enough problems once the shop realizes that your car is not a Prius 5, but they may let it slide.
    iPhone ?
  10. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Some places like Costco may have a policy that they will only install tires that are OEM sizes but other places like Discount Tire Centers (at least in my area) couldn't care less and will do whatever you wish.
  11. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    Our Costco wouldn't even install a tire size that was an option on a higher trim level for our model when I installed 17 inch rims on our vehicle that came with stock 16 inch wheels. They said they only install tire size that the vehicle comes with from the factory.
    SCH-I535
  12. The Critic
    3,193
    2,330
    CA
    Same here, and from a liability standpoint, that is a very poor policy.
    iPhone ?
  13. Eric Henley
    60
    I'm already set on that tire size... Also have read other people's post that went with the 45's then wished they got the 50's... Regardless I'm now curious if actual vehicle raises half an inch? Or does the tire just fill in gap?
    Can't use common since to figure this one out
  14. xliderider
    8,140
    3,274
    Honolulu, HI
    Both, the car will be raised 0.25 inch and the tire will fill the gap by 0.25 inch.
    SCH-I535
  15. SuperchargedMR2
    673
    179
    Vancouver, WA
    As long as the tire diameter is around the same it's stupid that places like Costco won't install a better tire size than OEM. A 205/50R17 is a little narrower for better mpg then the 215/45R17 but is the same diameter as the 195/65R15 size to make the speedometer more accurate. It just goes to show that the guys at Discount Tire/America's Tire know a lot more about wheels & tires.
  16. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Just because Costco has a policy for liability reasons does not mean Discount Tire Centers know more about wheels and tires than Costco, but I am not a fan of either places.
  17. SuperchargedMR2
    673
    179
    Vancouver, WA
    Costco has made a policy that makes no sense because it was made by management that has zero clue about cars, tires & what is the proper fit. How can there be any liability when a 195/65R15 & 205/50R17 have the same diameter and the Prius come with both wheel sizes. This is why DTC knows so much more because even upper management understands cars, tires & wheels unlike the same people at Costco.
  18. xliderider
    8,140
    3,274
    Honolulu, HI
    It's most likely about risk management rather than knowledge. It's called CYA. ;)
    SCH-I535
  19. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Yep, Costco is a big business. There was a stupid class action lawsuit against them for not adjusting gas volume for temperature :rolleyes:
  20. xliderider
    8,140
    3,274
    Honolulu, HI
    Lol, Costco is already selling their gas at low margins, or maybe even at a slight loss, and ppl want to bring up a dumb class action lawsuit?
    I'm sure the lawyers were drooling all over that one because they're the only ones who would get a lot out of a class action lawsuit. :rolleyes:
    SCH-I535
