Installed Rebuilt Hybrid Battery, Car Not Starting.... Help!!!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TommyD13, May 27, 2015.
  1. TommyD13
    TommyD13 New Member
    Fort Worth, TX
    My dad and I just took my Hybrid battery (06 Prius) to get cells replaced. Got home, hooked everything up, and now the car won't start. The accessories come on, lights come on, but no start-up. We also got a message about the parking brake, and to park on a flat surface... we were on a flat surface. Any ideas? We are recharging the 12v battery now to see if that has anything to do with it.
  2. ChapmanF
    15,924
    Do you have a Mini VCI or any other kind of Prius-capable code scanner to read out the condition of the battery?
    -Chap
  3. SageBrush
    SageBrush Senior Member
    11,627
    2,531
    Southwest Colorado
    Who installed the 'replacement cells' ?
    Or do you mean that one person worked on the pack and a different person took it out/installed ?
    A clear story would help us help you.
  4. TommyD13
    TommyD13 New Member
    Fort Worth, TX
    We scanned for codes and there were no codes.
    A different guy replaced the cells. 4 to be exact were bad. It was a guy at a repair shop that has done thousands of replacements.
  5. SageBrush
    11,627
    2,531
    Southwest Colorado
    Google how to install the main orange plug correctly
  6. TommyD13
    TommyD13 New Member
    Fort Worth, TX
    Yeah. It's in right.
  7. JC91006
    16,496
    8,406
    If the orange plug is plugged correctly, then it would only be your 12v battery. Once that's charged, it should fire right up.
  8. ChapmanF
    15,924
    I'm skeptical, as the original post reported accessories and lights coming on, and an MFD message....
    What did you use to scan for codes? Some scanners will not show you any info from the battery and HV ECUs.
    If you do have a Prius-capable scanner, what does it show you for the 14 battery block voltages, the overall min and max voltage and state of charge?
    -Chap
  9. bisco
    49,735
    how many miles on her?
