Installed Toyota 86GT 17” Wheels
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Allshookup, Sep 19, 2020.
  1. Allshookup
    Allshookup Junior Member
    Alvarado, Texas
    I finally got everything I needed to install the 2018 Toyota 86 GT 17” wheels I got last month.
    On the front I had to install longer wheel studs and 7mm hub centric spacers so that the wheels should clear the caliper. I also installed aluminum hub centric rings 56.1mm OD to 54.1mm to make up for the slightly larger bore on the new wheels.
    On the rear I installed 10mm hub centric spacers. I had to grind about two or three millimeters off the factory studs. I also had to grind about two or three millimeters off the spacer studs as well. This was don’t to prevent the new lug nuts from bottoming out.
    The new wheels require different lug nuts so I had to get 20pc M12 x 1.5 Chrome Radius/Ball Seat Acorn Lug nuts ( Dorman 611-075 EQUIV.)
    I also went ahead and had all new tire pressure monitoring sensors installed in the new wheels. I documented all of the serial numbers needed so I could have them programmed into the car.
    Took it out for the first spin and it drives great, no problems at all.
  2. black_jmyntrn
    black_jmyntrn Senior Member
    1,729
    411
    2013 Prius Plug-in
    Looks good! thanks for the information on what needed to get these to fit.
  3. Ben Reader
    Ben Reader New Member
    Tampa, FL
    2015 Nissan LEAF
    That's amazing! If ever you're looking for spare aftermarket tires and rims, might as well check out these wheel and tire packages I've seen online. They're being sold off for a very affordable price.
  4. Steph1972
    Steph1972 Member
    65
    53
    St Adolphe D’Howard
    Four Touring
    Nice done , unbelievable how the Prius get a complete different look just by changing the wheels .....
    Jim Swart likes this.
  5. Mendel Leisk
    42,369
    Are the tires Primacy MXM4 in 215/45R17; just curious.
  6. Jamlim
    Jamlim Junior Member
    24
    22
    Bay Area, CA
    IMO those Subaru/Toyota wheels are the best looking set, i just wish they fit Prius w/o modifications.
