Installed TRD "Prius Plus" springs
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Loading..., Apr 26, 2012.
  1. d2mini
    d2mini Active Member
    519
    106
    Houston
    Ya, the wheels, your choice of lowering springs and your choice of bar can be had for around $1,800 shipped. I'm not sure what the body kit goes for but I think there are better options out there for 2010-11. I'm still waiting to see what they do for 2012 since the front fascia has been tweaked.
  2. rickelchilango
    rickelchilango Junior Member
    32
    Really think so, eh? Does it depend on how one drives? Also, how difficult is it to install (sway bar), do you know?
  3. rickelchilango
    32
    I believe I saw the body kit for $865 on eBay.. All this plus install, but still lower..
  4. Danger
    Danger Member
    175
    22
    Frisco
    How many fingers for the wheel gap on stock 15"s?
  5. joerockt
    joerockt Junior Member
    97
    27
    Looks great. Getting the TRD springs, sway bar, and Tanabe tower bar installed on Saturday. Wheels to come soon after.
    mnml and F8L like this.
  6. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    About 4 in the front and rear.
    Here again is my old 2012 Three on TRDs with 205/50/17s. Less than 1 finger gap in the rear. Maybe 2 in the front.
  7. Danger
    Danger Member
    175
    22
    Frisco
    THANKS F8L!! That helps alot. What wheels were you running with the 4 finger gap? They don't look stock? I really only wanted a drop of 1" and I only know of the modellista springs. I always read the TRD springs lower 1.3" which is a bit much for me. But with stock wheels or even 16" and the right tires it should still look nice. I know the 17" look great with the TRD but I carry people in my car often and my rear would possibly scrape with 17" and 205/50.
  8. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    The picture is of my 2012 PIP but it is the same as the non-PIP. The PIP has different wheels.
    The TRD springs are a really mild drop. Because the rear wheels are able to tuck into the wheel well, you would have to carry some very heavy people to cause scraping. Still, two 200lb people and a trunk full of gear could cause a problem. In that case the 215/45/17 tire will provide more clearance since it is shorter than the 205/50/17 and the 195/65/15. My point is, if you are worried about scraping, choose a coilover kit or use the TRD springs but choose your wheel so it has no less than a 45mm offset then use a 215/45/17 tire. The Ecopia EP422 is pretty comfortable and fairly narrow in that size. :)
  9. BigPete
    BigPete Member
    149
    56
    Plymouth, UK
  10. xjustinx
    xjustinx Junior Member
    35
    san clemente, ca
    do these springs work for a 2013 prius? How do you think it would look with 225x45x18?
  11. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    That's how the wheel wells are designed. To reduce the gap in front and increase it in the rear use H&R springs instead of TRDs.
  12. joerockt
    97
    27
    They do. Getting mine installed this weekend.
    For me, the 18's hit that threshold of looking over sized on this car. Check out the aftermarket wheel thread to get an idea of how they will look.
  13. ockevin
    ockevin Active Member
    493
    148
    Orange County
    225/45/18 will rub and are too tall if you are lowered. You need 225/40/18 tires.
    F8L likes this.
  14. BigPete
    BigPete Member
    149
    56
    Plymouth, UK
    I always think either the gap front and rear needs to be the same or more in the rear to look nicer. More in the rear is always nice, then you get a more aggressive front down look and when you pile the kids in the back or whatever the car sits flat.
    Apostle39 likes this.
  15. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Agreed. Unfortunately they are not built like that. The GenII was even worse. After 100k miles the nice person ends sags like you're carrying a load. :(
  16. BigPete
    BigPete Member
    149
    56
    Plymouth, UK
    Well if that's the case H&R Lowering springs I am sold on. I live in the UK and Toyota don't sell the lowering springs over here and will not import. So as much as I'd like to keep things OEM parts as much as I can, looks like I won't be on the springs.
  17. Bill Norton
    Bill Norton Senior Member
    2,233
    748
    MONW, Ks.
    2019 Prius
    L Eco
    I still haven't installed mine, but just to review,,
    Lowering springs don't allow the tire to go any higher in the wheel well at full bump.
    That's controlled by the bump stops, which are built into the struts and shocks,, is this correct?
    And with the 'Prius Plus' setup there is no way you will have interference in the wheel wells, correct?
  18. ockevin
    493
    148
    Orange County
    Big Pete...
    You should order the springs on ebay and have them shipped to you.
  19. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    What is the "Plus setup"? The wheel wells are the same.
  20. ockevin
    493
    148
    Orange County
    The plus setup is the TRD springs
