Installing an android auto radio.
Discussion in 'Gen 2 Prius Audio and Electronics' started by Prius92, Jul 30, 2025.
  1. Prius92
    Prius92 Active Member
    595
    122
    Iowa
    This came with a backup camera, my Prius has the factory backup camera.
    The new radio has a backup camera input, but I'm fine with still using it through the MFD.
    Do I need to do anything different with the new radio itself, or does the backup camera still work through the MFD?
    Thanks
  2. PriusCamper
    PriusCamper Senior Member
    13,348
    5,396
    Pacific Northwest, USA
    Long ago there was a problem with the MFD working properly in Gen2 Prius if you installed an aftermarket stereo. The fix was either adding a resistor to a specific wire, or leaving the old stereo plugged in and hiding it under the seat. But that was more than a decade ago. I think aftermarket stereo makers now resolve that themselves by having more compatibility in their systems...
    If I were you, I'd use both back up cameras and use the backup camera that came with the stereo in a more unique location so you have more camera angles to see what's going on behind your car.
  3. Prius92
    595
    122
    Iowa
    It looks like the new radio has that resistor installed.
    PriusCamper likes this.
  4. highmilesgarage
    highmilesgarage Active Member
    494
    182
    Kansas City
    if you have a JBL system then you need an optical adapter which is an added expense unless you can wire it directly to the amp. Non-JBL is a direct connection to the speakers.
