Installing DRL's in a 2006, but hit a snag....
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Confrad in VA, Mar 31, 2019.
Tags:
  1. Confrad in VA
    Confrad in VA Junior Member
    23
    Powhatan, VA
    I just installed daytime running lights in my daughter's 2006 - (the flexible LED type that is normally white, but flashes yellow with the turn signals). He's my problem... I need to find a fuse under the hood that I can use that is powered on with the cars ignition. I installed it for testing using the horn fuse location, but since it is hot all of the time the lights would never be off. It seems that Toyota decided not to add an ACC fuse, which would be perfect if they had. Any suggestions on where to get power under the hood?
    I would prefer not to use a source that would require her to turn on a switch, if possible.
  2. Entropy4All
    Entropy4All Junior Member
    What about fuse 3? It's supposed to be for daytime running lights
    2003-2009 Toyota Prius (XW20) Fuse Box Diagram » Fuse Diagram
