Installing receiver hitch question
Discussion in 'Gen 3 Prius Main Forum' started by Frogerelli, Mar 21, 2013.
  1. Frogerelli
    Frogerelli Junior Member
    38
    Fort Smith, Arkansas
    Car is a 2010, the underside of it is covered by a plastic belly pan. There is an oriface on the left side of the pan for the bolts that the hitch fastens to the car with. The right side, by the muffler does not have the belly pan near it. If I have the correct hitch, do I need to modify the pan to bolt on the hitch or will it fit through the oval hole in the pan?
  2. retired4999
    2,652
    625
    Eau Claire, Wi.
    Should bolt right up. I think you use one of the muffler bolt holes, with a longer bolt shipped with hitch. If I'm wrong someone chime in.
  3. Sfcyclist
    Sfcyclist Senior Member
    1,621
    375
    SF, CA
    All the hitches use the same bolt holes. I just installed mine hours ago.
    Are you having problems fitting it through the plastic cover? The key was on the Curt hitch, I bet the same with others, is angle the drivers side into position first, then lift up the muffler side into place.
    These photos aren't too helpful but here's the link;
    Done deal, got my Blizzard White Persona! | Page 2 | PriusChat
  4. Sfcyclist
    1,621
    375
    SF, CA
    The right/passenger side bracket, I used 2 new bolts. 4 new bolts were included and torqued down to 75 ft lbs.
  5. retired4999
    2,652
    625
    Eau Claire, Wi.
    Nice install pic's, good job looks great! :)
  6. detroit11
    detroit11 Junior Member
    can you use the existing bolts ? for the hitch. or do you need different ones ?
  7. retired4999
    2,652
    625
    Eau Claire, Wi.
    Four new bolts come with the hitch. I think you should use some of them where need, extra length because of the added metal thickness of the hitch.
  8. detroit11
    I have a hitch but it didnt have any additional hardware thats why I was asking :)
  9. retired4999
    2,652
    625
    Eau Claire, Wi.
    Oh! Just check for length when installing you may find they are long enough. If you think you will need longer ones, any parts house will have them they are really cheap. :)
  10. retired4999
    2,652
    625
    Eau Claire, Wi.
    You may find that you need one by the muffler because you are adding the metal thickness of the muffler bracket also!
  11. detroit11
    roger that ty
  12. Sfcyclist
    1,621
    375
    SF, CA
    The bolts provided are also higher grade.
  13. retired4999
    2,652
    625
    Eau Claire, Wi.
    correct! Grade 8 bolt would be good.
    TwoUnderPar likes this.
  14. detroit11
    Does anyone know the exact size of the bolts needed ?
    I will have to go pick up some more. I didnt the hitch did not come with any hardware at all.
  15. mnsweeps
    mnsweeps Member
    108
    16
    Los Angeles CA
    btw what brand of hitch did you get? I have a 2012 Prius
  16. detroit11
    I dont know I cant find a brand but its tubular
  17. Sfcyclist
    1,621
    375
    SF, CA
    Only tubular one I know of is Curt.
    Bolt size is M12-1.25x40 hex bolt. Came with 4 conical washers too. Per Curt, torque to 72ft lbs.
  18. detroit11
    awesome, thank you
  19. Frogerelli
    38
    I bought a tubular Reese hitch through Amazon for $106, delivered. Now if I could only find an equally good deal on a Saris Thelma...
  20. Sfcyclist
    1,621
    375
    SF, CA
    How's the finish? Curts finish looks durable and glossy.
