Installing speakers...need some help!
Discussion in 'Gen 2 Prius Audio and Electronics' started by Experimental, Jan 13, 2007.
  1. Experimental
    Experimental New Member
    Atlanta, GA
    Hope everyone is having a great new year so far.
    I purchased two pairs of Pioneer 6.5" 3 -way speakers - model TS-A1671R for my fiancee's '05 non-JBL Prius. I was able to get a fantastic deal on them, and I'm fairly happy with how Pioneer speakers sound for the money. The two big selling points for me.
    I've seen Sparky's write-up on his install, and while it has been very helpful so far, I have reached a snag. Unlike his Infinitys, these Pioneers did not come with adapters to mount the speakers into the door. After calling several car audio shops including the local Best Buy & Circuit City car audio departments, I have come to the conclusion no one makes adapters for the Toyota Prius. In fact, I get the feeling that most (if not all) installers prefer to just drill holes.
    While I have been given the green light to drill holes, I have come along another problem. The speaker hole in the doors are so big, the speakers are about ready to go all the way through the doors...thereby leaving very little, if not any, room to drill the mounting holes I need. I'm basically out of ideas and looking to you all for help.
    What have you all been doing to mount your speakers? I don't mind using brackets...in fact I have done it in the past with other cars. Thanks in advance for your help!
    Brian
  2. kDB
    kDB New Member
    241
    Fenton, MO
    The simple thing to do would be getting some thin plywood (or decent sheet metal) and make your own bracket. Just cut a piece that will cover the hole in the door, with a hole in the middle to mount the speaker to. The door panel gives plenty of room.
  3. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    Drill out the oringal spacers and then use them to make a stencil for the spacer (I recommend MDF). Make sure the holes line up perfectly. Then all you need to do is cut a hole for the speaker, which is easy to size if the speakers include mounting rings to use as a stencil.
  4. priusenvy
    priusenvy Senior Member
    1,765
    Silicon Valley, CA
    You could also get a pair of plastic adapters from Scosche (sp?). I used a pair for the speakers in the rear doors.
  5. priusenvy
    1,765
    Silicon Valley, CA
    I looked up my order - I used Scosche SAC656 adapters.
    IIRC, I mounted the metal rings that came with the speakers to the adapters (with short machine screws and nuts from Home Depot), and then attached the speakers to the rings using the supplied hardware. I used two of the existing holes in the car door, and drilled a third one.
  6. GeoGeek
    GeoGeek Member
    360
    31
    Auburndale, FL
  7. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    Crutchfield sells some adapters like this, although not specifically listed for the Prius look like they should work. That may be an option for you if you've not got the tools or the time to make something out of MDF.
  8. Experimental
    Atlanta, GA
    Just to follow up:
    Thank you everyone for your replies. I used MDF board to create my own speaker brackets, and they work pretty darn well. It gives plenty of clearance. It's easy to cut to the specific shapes needed. It really worked out for the best.
    On the downside...the Pioneer speakers are having issues. I will post that in a seperate topic and insert a link to this post for further info. Thanks again for everyone's input!
    Brian
Loading...
