Installing the OEM NAV on a non-NAV equipped Prius
Discussion in 'Gen 3 Prius Audio and Electronics' started by green curry expert, Jun 28, 2009.
  1. green curry expert
    green curry expert New Member
    105
    Toronto, Canada
    Agree. I installed an ipod interface in my 2002 Corolla and it involved removing the radio and plugging the interface into the CD changer port. The most difficult part was getting the right cables and knowing where to plug them (fortunately the kit included all the cables and instructions).
    I wonder if the GPS antenna is shared with something else (eg: satellite radio), as all cars are "pre-wired" for it.
  2. green curry expert
    105
    Toronto, Canada
    Here are more things I discovered after driving the car for a month and interacting with users in this forum:
    The dealer will install the NAV but it's not the same as the OEM nav. It's a Toyota unit that fits in a standard double-DIN slot. They are still awaiting the bracket for the 2010 Prius.
    There IS information on the TIS site on the harnesses behind each head unit (JBL, non-JBL, NAV, etc). The folks doing the speed sensor mods were able to get info on which pin to tap. Someone close to me is moving to the states so he'll finally be able to sign up for a TIS login for me.
    The same speed sensor wire is present in my car. My headunit can sense the speed of my car and adjust the volume automatically. Hopefully the harness that it comes in is the same as the one on a NAV equipped Prius.
    There is a voice command button as well as bluetooth call and hangup buttons on the steering wheel (the same set of buttons on a NAV equipped Prius). Hopefully the connectors are the same so I don't have to cut any wires. In addition, the microphone is located near the rearview mirror and is present in all bluetooth equipped cars (NAV or non-NAV).
    There is a GPS antenna located under the top dash cover. This needs to be installed and the dash has to be disassembled for this. The GPS antenna must be located very close to the bottom edge of the windshield because the roof of the car affects reception. Therefore alternate locations to install the antenna is out of the question.
    The dash is easy to disassemble and reassemble. The people who installed aftermarket subwoofers can testify this.
    So the following questions are still pending:
    Is the backup camera interface on a Canadian non-NAV Prius the same as a NAV equipped Prius (on Canadian cars, the backup camera display is built into the rearview mirror). I wonder if it's possible to re-route it to the NAV once it's installed.
    The same question about the harnesses which I look forward to finding out once I get access to TIS.
  3. Tideland Prius
    16,683
    So you're gonna install the Toyota "lite" nav?? The one found on the Yaris/Corolla/Matrix? Or a full one but just happens to be 2-DIN like the Tundra?
    Hmm, the feed shouldn't be any different. I don't see a "stretching" issue with the image if it were to be displayed on a 7" screen instead of a 3.5" (or whatever the size of the mirror camera is)
  4. chancejd
    chancejd New Member
    34
    Houston, TX
    GC Expert:
    Please keep us posted on any updates with Toyota! Did they tell you if it will interface with the Radio (Audio controls via display)?
    Chance
  5. jwalker
    jwalker New Member
    st louis
    give me the url address for the technical information website and i will be happy to ask the question for you. i am going to have the Nav added to my mod 4 which came without it so i am very interested in this also. i am also told that some govt moron came up with the idea that you have to stop to change the gps route. i have one idea to override that problem
  6. barbaram
    barbaram Active Member
    912
    70
    Trenton, NJ
    I would not bother. If you are going to the expense of getting NAV I would buy a Garmin or something that works better. I hate this unit. I dislike it so much I am going to send Toyota a rant.
  7. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    Could you kindly explpain *what* it is you so hate about it??? Also, what car have you put it in - from your list, it does not appear you own a Camry (???) Sorry if I am missing something here!
  8. green curry expert
    105
    Toronto, Canada
    Definitely getting the original OEM one (provided the harnesses are the same and I don't have to cut too many wires). Just love the look and function of it.
    The display on the mirror is very high res (I was pleasantly surprised). So I suspect the resolution is the same. Hopefully the wiring is accessible inside the dash and the harness is the same.
  9. green curry expert
    105
    Toronto, Canada
    Yea, it also has radio and audio controls, since it replaces the original stereo. I'm not sure about steering wheel controls though.
  10. green curry expert
    105
    Toronto, Canada
    I know it won't be as good as my Garmin. But for finding addresses in the city and checking where I am, it's good enough. I also look forward to installing the iPod interface (the new one which includes USB drive support, requires the NAV headunit, and doesn't disable satellite radio). And if that's not enough, I can always bring my Garmin just in case. :)
  11. Tideland Prius
    16,683
    They're both OEM though... even if one looks kinda aftermarket haha.
    Let us know how it turns out! Hopefully it won't be as expensive as the guy who tried to install a hybrid nav to his TCH.
    P.S. you can do multi-quotes! Click the button w/ the 2 chat bubbles to add a post to your reply
  12. rrolff
    1,610
    246
    So Cal
    Newest 2 Din Indash Car DVD GPS Navi Stereo iPOD PIP - eBay (item 260451816490 end time Sep-21-09 03:23:30 PDT)
    There are many aftermarket NAVs like the Lightinthebox.com... On paper some look promising (DVD, IPhone 3.0 support, steering control support, simple interface for a $40 night vision CCD backup camera - with auto on when in reverse etc etc etc)...
    There's even a DTV interface...
    They run WIN CE 5.0, and have huge GPS potential (can even run TomTom maps)... For me if it's 95% of my Garmin, that's fine - I'll move the Garmin to the attic until I head over to France :)
    As I am running stock P II stereo - this is an attractive option...
    Anyone played with these??? They are relatively cheap ($280 - $500) - but have no idea about sound quality/functionality.......
    No flames please about DVD / TV playback - I know the laws, and would only use it when parked:rolleyes:
    TTFN!
  13. nylion
    nylion New Member
    167
    61
    Seattle WA
    I may be wrong, but I believe the Nav antenna is in the base of the radio antenna on the roof. You would need to swap that part (and the wiring harness as well). Is this really worth it?
  14. green curry expert
    105
    Toronto, Canada
    Other users also suggested this to me. My only concern is the quality. Will it live up to the rest of the car?
    I also doubt it will integrate with the touch tracer controls.
    From the information other Priuschatters had provided me, and from other posts, it's inside the dash for sure.
    If it involves a lot of extra wiring, then I would go aftermarket instead. But so far it looks very easy.
  15. jwalker
    jwalker New Member
    st louis
    Due to a lousy salesmen i got a 2010 prius lV without the Nav or back up camera. took it to a place in st louis and they pulled the OEM radio unit out and installed a clarion $800 unit. i now have navagation, satellite radio,ipod plugged in, and also a back up camera that displays on the unit and not the rear view mirror. the whole job cost $2700 and it is i am sure better than what would of come with the unit. so it is doable but get a good installation company and not best buy or other generic installers.
  16. rrolff
    1,610
    246
    So Cal
    What did they do for the surround plastic - to make the clarion fit???
    Sounds nice - can you post pictures? Did it really cost $1900 to install????
  17. green curry expert
    105
    Toronto, Canada
    My goal is to try to install the OEM headunit first. I'll get the aftermarket unit (I'll most likely go with Kenwood, which is standard double DIN and brackets are avaliable now) if it's technically impossible to install the OEM one.
    I should have the information I need soon. Will attempt the install in the next month or so.
    rrolff, how long did it take you to open the dash? This is my biggest concern. The OEM GPS antenna is located just under the windshield, to the left of the MFD.
  18. rrolff
    1,610
    246
    So Cal
    *if* you read the threads, It should take (taking time) around 8 minutes to gently pull the surrounds from the stereo - then with a 10mm extended socket, spend 3 minutes removing the screws - then pull out the head unit (1 min), then unplug it (2 min). For me (or our beloved Frenchie), probably 3 minutes to remove the HU.
    You could opt to place the antenna in a crazy place on the dash, or read the thread - place it in the tweeter area - simple, line of sight - and the cable just drops down through the opeing to the drivers feet, and you route it up to the HU. This is a 15 minute job with no experience. maybe 5 if you know whats up.. My antenna works great from that location (look at it - why wouldn't it???).
    So all in, Spend an hour, and enjoy your accomplishment... My setup was *plug and play* meaning no wires to cut, just plug into existing Toyota stuff...
    What surround are you using (plastic)??? Where did you get it???
    Get the kits - make sure they supporting steering buttons, bluetooth et al, and have fun :rockon:
    Rear cam is another animal - not a 20 min job - but worth the time... Get a good OEM cam - I bought a infra-red night sensing thing, and may swap it due to the picture (was hoping to see a really clear color pic).
    Parking sensors (removing rear bumper), are another fun exercise :cool:
    Edit: I will add that the GPS software is kinda a nice key to the whole equation... If your system allows it (and many do), you can run Garmin, TomTom, iGO8 etc... I've been playing with iGO8 for a while - and it is amazing as far as GPS' go. We have a Garmin - but that's now for trips.
    I can't run Garmin, as I have WinCE 5.0 (it runs 6.0) - but am going to play with Tom Tom soon...
    Feature I most love - the Brit guy explaining *sternly* "You are over the speed limit" at a preset number... Feature that totally annoys me - the chick's voice naggingly saying the same thing (you have to hear it). Many voices to choose - and it's entertaining...
  19. green curry expert
    105
    Toronto, Canada
    Finally got a chance to look through the TIS documents. It is possible to install the OEM NAV but it'll require some extra wiring. There are six harnesses behind the NAV unit, and five behind the non-NAV one (both radios are JBL equipped, BTW). In addition to the missing harness, one harness is different. The harnesses terminate into one or more jumper blocks.
    Looks like most of the wiring are within the jumper blocks. I assume it's easy to jumper two points within the same jumper block. But if a connection is between two different jumper blocks, is the wiring already there?
    Hopefully an expert who has worked with the wiring can comment on this.
    [update] Another interesting tidbit, the backup camera in the Canadian non-NAV Prius (with camera display in the mirror) and the backup camera on the NAV equipped Prius are identical. The harness on the Canadian Prius is different, and has an extra jumper block in between. Electrical connections are the same.
  20. green curry expert
    105
    Toronto, Canada
    Just finished downloading all the relevant documents from TIS (plus the repair manual for my Corolla). Now it's time to digest all the information.
    Looks like two harnesses are missing. One (L37) replaces an existing harness (L45) and has a few extra plugs for stuff like the backup camera. The other is completely new (L42) which contains the reverse signal, parking brake status, etc. This one terminates to several junction blocks. So for now I need the following: the two harnesses I mentioned earlier, the GPS antenna, and the NAV itself.
    I have a feeling L42 is already in my dash, unused (when I opened the dash of my Corolla, there were a few unused wires, hope the Prius is the same). My next step is to actually open the dash and see what's inside. If L42 is not there, then I need to connect some wires. I know which pins to connect to, but actually how to connect it, that's another thing I have to figure out...
    I already have the backup camera from the Canadian premium package, and I as mentioned before, it's identical to the one used with the NAV. I'm planning to leave the camera connected to the mirror and not connect the reverse wire to the NAV (so the backup camera stays with the mirror, and a passenger can enter destinations while I'm backing out of a spot).
    Update:
    The connectors for the satellite radio are also missing. On the nav equipped Prius, the satellite radio is located under the driver's seat. As a result, on the non-nav (but JBL equipped) Prius, the satellite radio is built into the headunit. Therefore, to install the OEM nav, the OEM satellite radio must also be installed (and I do use the satellite radio).
