installing used entune & navigation touch screen
Discussion in 'Prius c Audio and Electronics' started by Anas Almustafa, Apr 10, 2014.
  1. ROLOPR
    ROLOPR Member
    441
    85
    Puerto Rico
    I place it in top of the glove compartment, but I remove part of the dash to do it.
  2. SamanthaC0716
    SamanthaC0716 Active Member
    333
    112
    In the space where that little tray is, near the AUX & USB ports? Or actually in the glovebox?
    Thanks for your replies.
  3. SamanthaC0716
    333
    112
  4. wmo168
    wmo168 Member
    234
    42
    South Florida
    I put my sirrus and GPS antenna just above the middle ac vent inside on top under the trim piece. it will see thru plastic, no need to put it outside of the dash
  5. SamanthaC0716
    333
    112
    That's excellent. Thanks.
    iPhone ?
  6. Tim Lillis
    Tim Lillis Junior Member
    36
    Grand rapids
    2014 Prius c
    What Sirrus antenna did you use ? Did you buy a shark fin adapter?
  7. Priusvolt
    Priusvolt New Member
    What 3 wires did you tap into
  8. Priusvolt
    Which wires did you tap into
  9. Priuslover09
    Priuslover09 Member
    353
    Dc
    I think dvd map could do it but then you would need a new display for the maps it’s easier to use your phone for maps instead
  10. dubit
    dubit Senior Member
    801
    502
    Indiana
    2016 Prius c
    Hey, um... I don't think you two are going to get a reply. The thread is nearly 4 years old.
Loading...
