Installs & Reviews of Goodyear Assurance TripleTred's
Discussion in 'Gen 2 Prius Accessories & Modifications' started by amped, Nov 8, 2004.
  1. daniel
    14,487
    1,519
    Spokane, WA
    <div class='quotetop'>QUOTE(amped\";p=\"52440)</div>
    You gave the tire guys a box of day-old muffins? Come on, Amped! The least you could have done was give them fresh muffins. When I volunteered at the homeless shelter we got mountains of day-old bread products. They look fine but they taste awful.
  2. wb9tyj
    wb9tyj 2017 Prius Prime Advanced
    389
    95
    Indiana and Nevada
    after having on the goodyear TT now for a few miles...so slips, no slides, no errors...mileage seems to be about the same...and the footprint is sooo much better...
  3. amped
    amped Senior Member
    3,892
    694
    Columbia River Gorge, Oregon
    Re: Installed Goodyear Assurance TripleTred's Today
    Joe, congrats! I think you'll like the TT's. They really improve the car in every way. Sounds like you got a good deal, too. I forgot to mention that part of my savings was no need for new valve stems, another -$8, but needed for your car. I'll be interested in your impressions, especially regarding tire pressure. I landed on 42ff/40rr for best compromise for my needs (prioritize handling over ride), but you might like 40ff/38rr or something else for slightly improved ride quality. I wouldn't worry about the 4 lb. over torque, it's probably within the margin of error for a torque wrench. When you get 1,000 miles on your new TT's, I'd stop by and have them hand torque (not impact torque) the wheels again using the proper criss-cross sequence. It's what the owner's manual calls for on a new car, and is good practice whenever a wheel is removed.
    Daniel, all the Orowheat outlet had was day-old stuff. The banana-nut muffin I had tasted great, and they all looked better than the week-old donuts under the counter. :wink:
  4. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(priusenvy\";p=\"52945)</div>
    The stock Goodyear Integritys are M&S rated, so they're considered "snow" tires too.
    You must drive on different roads than I do. I've been going to Tahoe in the winter on I-80 and US-50 for twenty years, and I've only ever seen R2 conditions (chains required except for 4WD with snow tires).[/b][/quote]
    I thought the M+S rating was no longer allowed as a snow tire? That is, to be qualified as a true "snow' tire under RMA/CMA, the tire must have that "snowflake" emblem on the sidewall in addition to M+S.
    It's very confusing to see a skimpy all-season tire labeled M+S, when it's obvious you'd get stuck in 2 inches of snow. Professionals appear to achknowledge this confusion:
    http://www.tirerack.com/winter/tech/severe.jsp
    http://www.cbc.ca/consumers/market/files/c...ires/index.html
  5. amped
    amped Senior Member
    3,892
    694
    Re: Installs & Reviews of Goodyear Assurance TripleTred'
    I called my Goodyear dealer about the $50 rebate expiring today. He said that if the customer pays for them today, the dated receipt is qualifying proof for the rebate even if they're out of stock and are installed later. He said they're almost completely sold out of TT's in any size, but more are expected in next week.
    FWIW, I have no financial interest or any kind of connection to Goodyear! :)
  6. priusenvy
    priusenvy Senior Member
    1,765
    Silicon Valley, CA
    <div class='quotetop'>QUOTE(jayman\";p=\"52993)</div>
    Since the original poster and I were discussing road conditions in California, I was using the California Highway Patrol's definition of a snow tire:
    Link to CHP FAQ
    I have a 4-wheel drive vehicle. Do I have to carry / use chains? What do the "R" ratings which are associated with chain requirements mean?
    "R" ratings on snowy roads indicate chain requirements for various conditions. Some vehicles may not be required to use chains under all conditions, but all vehicles must carry chains. Most vehicles come equipped with snow tires. Look for M+S (mud and snow), All Season, or All Terrain, on the side of the tire.
  7. Tideland Prius
    16,547
    I agree with jayman. I believe under a recently introduced system, the snowflake logo is used for winter tyres while M+S remains for regular all-seaons
  8. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    priuisenvy, I thought I checked for the M+S on the Goodyear Integritys, but did not find them. Maybe I didn't. I tried to verify it on TireRack's larger view of the Integritys, but no luck. I have a feeling you are right, but I'm still gonna verify it for my own sanity's sake.
    I have only been to Lake Tahoe once. I usually go to Mammoth Lakes, where the roads are usually clear and the worst I have seen are R1 conditions. My sampling size may be small enough such that I'm wrong about R1 being about as bad as it gets. Regardless, I intend to be prepared with tire chains.
    amped, thanks. =) It actually rained relatively heavily (for LA) today, and I noticed that I did not have any hydroplaning issues that I had with the Integritys. So far they seem quieter, but I haven't had a whole lot use on them yet. They seemed a bit quieter on the grooved highway of the 118, but I'll have to try again on a dry day for a more accurate comparison. I set them to 42/40, but I absent-mindedly did it right after getting home, so they might be a bit lower when completely cold. Is it really a good idea to get them re-tightened at 1000 miles? I'm always curious when I have work done on my car, so I watched them put on my tires. They used a Hunter 9000 balancing machine (a friend told me the Hunter 9700 is the high-end machine that performance-oriented people want used in balancing their tires). They impact torqued the tires while my Prius was still raised, but then hand-torqued the wheels on after lowering my Prius. They did follow the criss-cross pattern, which I had only recently learned about recently. I wonder if I have been putting myself in any danger by not doing that on my old car. :oops:
    jayman, I guess I should have put quotes around my use of the phrase "snow" tire. I was trying to get at what you were saying when I said according to "CA DOT". It seems that M+S is a pretty weak definition, but presumably it is adequate to handle R1 conditions since they have made it the requirement (which I'm hoping was well-thought out and included a bit of conservative margin). I would only consider the mountain snowflake marked tires, true snow tires.
    Does anyone know where I can find the American Society for Testing and Materials traction tests results for any particular tire? I'm kind of curious on the specs of the TTs now. I know they do not have the mountain snow flake, which means that their snow traction is below 110, but I'd like to get an idea of where it is. From pictures of snow tires, it looks like they basically have thick deep channels in the tires compared to other tires.
  9. removeum
    removeum Member
    407
    El Paso, TX
    8)
    Regatta 2
    Warranty: Mileage 75,000
    Sidewall: B06
    Service Description: 86T
    Dry Traction 8
    Wet Traction 8
    Snow Traction 8
    Ride Comfort 8
    Quiet Ride 9
    Passenger Tire
    Integrity
    Warranty: Mileage 50,000
    Sidewall: B03
    Service Description: 86S
    Dry Traction 7
    Wet Traction 6
    Snow Traction 7
    Ride Comfort 8
    Quiet Ride 8
    Passenger Tire
    Assurance ComforTred
    Warranty: Mileage 80,000
    Sidewall: VSB
    Dry Traction 9
    Wet Traction 9
    Snow Traction 9
    Ride Comfort 10
    Quiet Ride 10
    http://www.goodyear.com/
    I just wonder if any one has tried the Assurance CT's vr TT's?
    Ben
  10. daniel
    14,487
    1,519
    Spokane, WA
    <div class='quotetop'>QUOTE(amped\";p=\"52988)</div>
    Okay. The stuff we used to get was called "day old" but was actually much older. It was after they could not sell it any more. Adequate when you're trying to feed 70 people out of a kitchen designed to feed 12, but doughnuts have never looked appetizing to me since.
    (Sorry for going so far off topic.)
  11. jayman
    13,439
    641
    Winnipeg Manitoba
    Removeum: As far as this issue of tires, I would never depend on the manufacturer to tell you how their tires rate. As far as they're concerned, ALL of their tires are good. At least Goodyear appears to think so.
    Firestone thought so too, until they had their a** sued by surviving family members. I would much rather trust independent reviews like TireRack, especially their customer comments.
    Ryogajyc: As far as using an impact gun to put the nuts on, I would only allow this if they used a Torque Stick www.torquestick.com. It's fine to mount the wheel to the flange, but I still prefer using a good torque wrench in the proper pattern to achieve the final torque. I've had issues with warped rotors and snapped bolts in the past by grease monkeys using the impact gun.
    Ryogajyc: As far as tire quality ratings, I discovered something disturbing when I looked it up at Tire Rack:
    http://www.tirerack.com/tires/tiretech/gen...eneral/utqg.jsp
    The DOT/NHTSA does NOT conduct the test, but has the tire maker conduct the test. So what the h***, the traction rating of AA or A or B could mean anything. If you're way better at reading Bureaucratic Bulls*** than I am, try reading:
    http://www.nhtsa.dot.gov/cars/rules/ruling...inal/Index.html
    Remember: Advil for cramps, Excedrin for migraines, Imodium G for gut-wrenching nausea! Bleah! :pukeright:
  12. ryogajyc
    985
    165
    Reseda, CA
    removeum, thanks, but I agree with jayman on that. Those numbers are comparison values made by the tire company and are probably only relevant within any tire type group, much less between tire companies. For example, I doubt comparing the snow traction ratings between a snow tire and an all-season would be valid. The all-season definitely does not qualify for the snowflake mountain snow traction rating, while the snow tire would almost certainly have to. Both of them could have a snow traction of "10". An example, would be the Goodyear comparison data for the TTs, which are actually missing from your list. To back up my assertion, from the Goodyear website FAQ:
    [hr:d5682680d6]Where can I get specific technical information or testing data about a Goodyear tire?
    All engineering data available to the public is provided on the respective product information brochure made available at the retail outlets or on the Goodyear website. Most technical or test data is considered proprietary and not available to the public. In some cases, some information may be shared but these inquires must be made in writing and mailed specifically to our Technical Center for review.
    [hr:d5682680d6]
    jayman, you said:
    [hr:d5682680d6]Ryogajyc: As far as tire quality ratings, I discovered something disturbing when I looked it up at Tire Rack:
    [hr:d5682680d6]
    Not exactly, from that link you provided:
    [hr:d5682680d6]When looking at UTQG ratings it is important to realize that the Department of Transportation does not conduct the tests. The grades are assigned by the tire manufacturers based on their test results or those conducted by an independent testing company they have hired.
    [hr:d5682680d6]The tire company hires an independent company to do the test. If the independent company has a single tire company as its sole customer, I could see potential problems. If the independent company has multiple tire company clients, chances are it is reasonably fair.
    Also, the traction rating you mentioned is for a wet skid test. I doubt this is the same test they use for determining snow traction, and hence the snowflake mountain symbol. I think I need the American Society for Testing and Materials traction tests results for that. It may be what I want is proprietary and unavailable to me. I suppose I could try writing to Goodyear, but my guess is that they could easily refuse me the info.
  13. jayman
    13,439
    641
    Winnipeg Manitoba
    <<based on their test results OR those conducted by an independent testing company they have hired>>
    The way I read it, the tire maker can do the testing in-house OR contract it out. Still sounds very subjective. I already have a migraine from trying to read that DOT/NHTSA thing about tire testing, but here is a weird fact I dug up:
    The tire maker is allowed to rotate tires every 800 miles!
    :roll:
    Well then, why the h*** wouldn't the tire last a long time if it gets rotated every 800 miles. That is about every two weeks by my driving. They only run the wear test for 7,200 miles.
    Don't get me started on that "M+S" thing either. It's pure bulls***, it doesn't mean anything. I guess the tire makers aren't outright lying their a** off, just engaging in a little bit of "puffery." Caveat Emptor!
    Which is why I think the Snowflake stamp is really a good step in the right direction. They actually specify a certain minimum snow/ice traction, though I would still prefer looking at a truly independent test like at Tire Rack.
    If you don't know, Tire Rack rents an indoor rink and they put different snow tires on identical cars or SUV's. They then measure acceleration from a dead stop, braking distance, and cornering ability.
  14. ryogajyc
    985
    165
    Reseda, CA
    Oops, a bit of inadvertant pot calling the kettle black. After reading that section, I assummed you had missed the independent test part, but it was me who missed the big "OR". :oops:
    The rotating every 800 miles seems a bit too much. I would say make the test 10000 miles and allow one rotation at 5000 miles.
    I have a less pessimistic view about the M+S thing. From what I've read (can't remember where, sorry), the M+S was an old standard which was valid when bias-ply tires were the norm. When radials came out, their superior traction abilities pretty much made every radial tire meet the old M+S requirement. From that, it seems that M+S is merely an old requirement, which probably has been used inappropriately by marketing teams. They probably offer adequate traction in certain conditions (i.e. R1 according to CA DOT). They aren't snow tires, or at least by modern definitions.
    I didn't notice these TireRack snow traction test results anywhere. Can you point them out to me?
  15. jayman
    13,439
    641
    Winnipeg Manitoba
    No problem. That's why I hate teeny-tiny fine print, as a tire manufacturer can claim all of their tires are just wonderful in all weather conditions, then you notice the asterisk. You can tell an entire team of lawyers were involved, can't you?
    You can look up the Tire Rack test results at:
    http://www.tirerack.com/tires/tests/testSearch.jsp
    Here in Canada, the CBC (Canadian Broadcast Corp) has a consumer affairs show called "Marketplace." Marketplace took on the issue of winter and tires about 5 years ago. They even travelled to Sweden to tape the Swedish government testing all season, regular winter, and studded winter tires on a glare ice test track.
    The Swedes apparently have a law requiring studded tires in winter.
    You can find the show comments at:
    http://www.cbc.ca/consumers/market/files/c...res/skinny.html
    http://www.cbc.ca/consumers/market/files/c...s/tirestud.html
    http://www.cbc.ca/consumers/market/files/c.../tiretests.html
    http://www.cbc.ca/consumers/market/files/c...res/update.html
    http://www.cbc.ca/story/news/national/2004...ires040129.html
    Hope this helps. I know the data can be intimidating, certainly trying to find it sure as h*** is! I suppose folks think I'm a wee bit eccentric what with my fanatical love of winter tires.
    Oh well, I've been called a lot worse things than "eccentric" and it usually rhymes with "duck shoe."
  16. priusenvy
    1,765
    Silicon Valley, CA
    I stumbled upon a couple web pages that may be of interest to those that require real snow tires (as opposed to people like me that just need something that will get us to the ski resort on the weekend, but don't live in an area where it snows)
    Winter Tire Information
    Certified Snow Tire List
  17. jchu
    jchu New Member
    1,063
    Nampa, ID
    Couldn't help but notice that at least 2, 1 Cooper and 1 Goodyear, M+S labeled tires made the Canadian list of certified snow tires. Perhaps might allow Jayman to lighten up just a little.
  18. jayman
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(jchu\";p=\"53903)</div>
    The Cooper Discoverer M+S is a dual-rated M+S and "Snowflake" winter tire for LD and some HD pickup trucks and SUV's. It has a special siped winter tread compound and will also accept studs. You can find more information at www.coopertire.com . It appears to be a good truck winter tire. I'll try them on my old Ford F-150 this winter as the current snow tires are +10 years old and getting worn.
    The Goodyear Eagle M+S tire is made for the Chevy Corvette and is available in Run Flat. According to the Goodyear web site, that tire is a "winter companion for Eagle performance radials." They make no mention of the new RMA "Snowflake" but the advertising DOES state it's for winter only.
    I'll lighten up once my winter tires arrive so I can at least drive up an icy parking ramp. It's also getting old creeping away at a green light with my foot flat on the floor and the VSC icon on. I just know I'm going to get rear-ended if this keeps up.
  19. mdacmeis
    mdacmeis Member
    133
    Michigan
    2018 Prius Prime
    <div class='quotetop'>QUOTE(ryogajyc\";p=\"52942)</div>
    Wheel nut torque generally has a tolerance of +/- 10 ft-lbs. Some are rated +/- 5 ft-lbs. If the torque is too low, the nut will loosen over time and you could lose a wheel. If the torque is too high the main consequence is that you may distort the brake rotor and/or bearing flange, which will result in the development of brake pulsation over time. Of course if you really over tighten the nut you could fracture the wheel or break the stud. 76 ft-lbs is fine.
  20. amped
    amped Senior Member
    3,892
    694
    Update from first post after a Winter and ~2,500 miles. The TT's performed well in almost all conditions encountered.
    In the dry, grip was more than adequate, high speed crosswind stability excellent at 42ff/39rr, noise levels undetectable so far, and ride quality remained very good except for a tendency to slap at expansion joints and potholes.
    In the wet, they're almost as good as a dedicated rain tire like the Potenza RE-950's I ran on an '04.
    Snow performance was better than expected up to ~4"-5". They gripped well enough that TRAC was usually quiet and unobtrusive, and if they did slip, regained traction instantly, at least in powder.
    We had a big ice storm last December. Nobody went far, including me. The center rib with the volcanic ash and chopped fiberglass bits sounds good on paper, but I wouldn't rely on these tires for ice traction. I had great fun exercising VSC though.
    Altogether, grip is improved enormously compared to Integritys, the TRAC light hardly ever comes on where it used to frequently with OEM rubber. The TT's are staying remarkably quiet, but only have 2,500 miles on them so that might change like it did on the Potenzas. Best of all, fuel economy seems to be nearly unchanged compared to the sloppy OEM's. The TT's offer a good alternative to the budget Integrity's, have a great warranty and are reasonably priced for the performance gains. I'd recommend them to almost everyone wanting an above average all season HR rated tire. It should suit the needs of 95% of Prius owners.
    I'm in the other 5%. On my '06, I'll be going back to a VR rated tire like the Potenzas, maybe Yokohama next time. A stiff sidewall tire really ads to my driving enjoyment, tightening up the steering and suspension and transforming Prius into a near-sports sedan. It makes for a more entertaining Prius, one that can handle twisty mountain roads with much greater confidence than almost any all season tire at any given speed. If only we could get the rest of the EU spec Prius *sigh*, but the tires go a long way in that direction. Just my style, and my 2¢.
