Instructions to disable the SKS without Techstream
Discussion in 'Gen 3 Prius Technical Discussion' started by adrianblack, Jan 10, 2010.
  1. Grit
    Grit Senior Member
    6,577
    4,229
    Wilkes Land
    o_O
  2. TheLastMojojomo
    TheLastMojojomo Active Member
    232
    181
    US
    The starter motor (MG1) for the engine is powered by the HV Battery, not the 12v.
    Your whole premise of the 12v turning the starter motor makes no sense. To me, 90% of what you wrote is wrong or extremely confusing. But maybe I just don't understand what you're trying to say.
    You talk about a yellow starting light on the power button. This would indicate your in IGNITION ON mode and not READY.
    Are you pushing the brake pedal while starting the vehicle? If your not pushing the brake pedal while pushing the power button, it will cycle through ACCESSORY MODE and IGNITION ON mode. Essentially 1 and 2 click of the key on a normal vehicle before the 3rd click that starts the vehicle. Your issue could certainly be caused by a weak 12v which causes all sorts of electrical issues, I just want to make sure you're not over analyzing.
    Here is a picture of my Prius in IGNITION ON mode. Notice the yellow start button?
    I find it weird you're having so many issues with starting your Prius even with a charger. The 12v only needs to maintain a moderate draw, far less than a conventional vehicle, for a couple seconds before the HV Batt charge system takes over and supplies the needed current to start the motor and run the computers.
    Your 12v must be complete toast.
    Also, while the SKS system drains the 12v battery faster than car systems without something similar, it is nothing crazy compared to what modern car electronics will do.
    All cars that sit for long periods of time will drain the 12v. 2-3 weeks without running the vehicle will begin to stress even a healthy 12v. If your 12v is unhealthy it could be less than that.
    Get yourself a BMK 12v Battery Maintainer so you don't have to worry about your 12v dying.
    Here is my setup for the Battery Maintainer
    You can also get a 5 amp NOCO charger that can likely reverse some of the sulfation that has occurred in your batteries preventing the 12v from holding a full charge and possibly causing some of your issues.
    I had a 12v that wouldn't hold a resting charge past 12.14 volts. The NOCO repair feature brought the resting voltage to 12.6+ volts.
  3. Aung
    Aung New Member
    Phoenix
    #43 Aung, Jul 29, 2021
  4. dboy
    dboy Junior Member
    Mid Tlantic
    My interest in disabling it is because I'm not doing any long drives right now. Just to the grocery store and what not. My battery died while not driving at all around Christmas and a roadside assistance person started it up by connecting to the battery terminals in the back. Note: when the battery is dead, it's pretty difficult to get to the battery because the hatch won't open at all. In December my 12 V is getting hit pretty hard. Short trips headlights, radio and the heat and defrosters on, it uses a lot of the 12 volt electricity. But if I only go a mile, the 12v doesn't have time to charge back up. My 2008 Prius has a button near the steering column to disable and power down the SKS.
  5. dboy
    dboy Junior Member
    Mid Tlantic
    I think those may be different frequencies and strengths than whatever SKS uses.
  6. Lottamoxie
    Lottamoxie Member
    435
    64
    Southeast US
    I just tried this procedure to disable my SKS system on my 2010 Prius.
    I tried it 2 times, using the full instructions posted upstream.
    Did not work. Never got the 2 beeps at the end, and the key fob, which I then put in my pocket, continued to operate the door. I touched the door handle as if to try and open it and it beeped twice as it normally would.
    After 2 times I gave up.
    For whatever reason, I cannot get the SKS system on my 2010 Prius to be disabled.
    This isn't a fix for disabling the SKS system, but I did acquire a faraday-type pouch, and when my car is parked, I keep my key fob inside that pouch, and in my house, or in my purse, which is with me when out and about. I don't know what else to try since so far nothing I've done has worked to disable the SKS.
