Instrument cluster display "shadow"
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by 9G-man, Apr 24, 2012.
  1. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    Does anyone notice a digital "shadow" to the electronic speedometer display? Below is a picture of what I'm seeing. It's not a viewpoint or reflection that goes away from a different angle. It's like there is an alignment issue or something.. I know the display image is a projection from below, to create a distant focal point. But I see this image shadow.
    The one in my 07 Prius doesn;t do this. Click on the pic below...
  2. ClaySacramento
    ClaySacramento Junior Member
    58
    Sacramento, CA
    I wonder if this is caused by the Touch Tracer Display that was added in 2010. It seems like the transparent layer where the touch tracer appears could cause the reflection shown in your photo.
  3. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    There's actually been threads about this 9G, it's there and can't be adjusted. I attribute it to the touch tracer in the Gen III. It's worse the closer you sit and less noticeable if your tall and sit all the way back lol.
    lensovet likes this.
    52,854
    i havn't noticed it, but i see it in your pic. i look more closely tomorrow. nite or day make any diff.?
  5. 9G-man
    1,273
    194
    Atlanta, GA
    Ok, thanks
  6. 9G-man
    1,273
    194
    Atlanta, GA
    Day or Night, bright or dim it's there. I noticed if I push on the plastic lense on the face of the cluster I can get the shadow to shift.
    Maybe we were supposed to get 3D glasses with the PiP.:)
  7. SimiPrius
    SimiPrius Member
    247
    60
    Simi Valley,Ca
    Not happening on mine.
  8. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I didn't see it at first on my 2010 but if you look closely it is there. It's negligible though, to me at least.
  9. Senthil
    Senthil Junior Member
    Did you find anything about this problem? I just bought 2012 prius today and I see the exact same thing what you have in the picture. Please let me know if you got this fixed? If this is really an issue, I would take it to the Toyota dealership.
  10. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    It cannot be fixed. It is a slight double image caused by the way the touch tracer is implemented within the unit.
  11. LenP
    LenP Member
    257
    69
    Morris County, NJ
    It looks like the image is being refracted by the thickness of the plastic lens giving it a slight ghost image. Not to much could be done to correct this problem now. If Toyota put an anti reflection coating on the back of the plastic screen it would help diminish this effect.
  12. Senthil
    Ok. I will take it to the dealer anyway and see what happens.
  13. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    If you have to take time off like from work to do it save your time, there is nothing they can do.
  14. Senthil
    I went to dealer today and they confirmed that this is normal :(
  15. slfarooqui
    slfarooqui New Member
    Land O' Lakes, Florida
    This is happening on my Prius, too. I love the car but this is such an annoyance.
