Instrument Lights - Let's Contact Toyota
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by keymusic, Nov 9, 2016.
  1. keymusic
    keymusic Active Member
    211
    113
    Southern California
    So it turns out that in the 2017 Prius Two (I assume also the 2016), the instrument cluster brightness does not work as stated on page 98 of the manual. It only works properly on Three and above. This did work properly on the 3rd gen Prius Two. During the day if you turn on the headlights or parking lights, in other words when you turn on the tail lights, the instrument brightness is not supposed to dim. That's the only purpose of the ambient light sensor on the dashboard in this model since it doesn't have auto-headlights.
    I have contacted Toyota and I was just put in a loop between them and a local dealership's service dept. This needs to get to the proper dept in Toyota so that it can be fixed. I'm assuming it's a simple software change, as long as the hardware is there, which it seems like it is. Also, it specifies that this works in the manual and I consider this a safety issue.
    Does anyone know how to contact the right dept in Toyota to start the process of getting this taken care of?
    #1 keymusic, Nov 9, 2016
    RCO likes this.
    52,883
    start with priusteam, here on priuschat. what is the dealer saying?
    RCO likes this.
  3. mark27lim
    mark27lim Active Member
    108
    104
    singapore
    you can try carista to play around with the ambient sensor sensitivity settings and see if that helps?
    iPhone ?
  4. keymusic
    211
    113
    Southern California
    I showed the dealer in a Two and Three on their lot, they didn't know anything about it.
    RCO likes this.
  5. keymusic
    211
    113
    Southern California
    According to the manual the customization settings are -2 to +2 to change the sensitivity, with 0 being the default. However, the not dimming the cluster lights in daylight function with headlights on simply isn't working at all in the Two. Hence changing the sensitivity won't do anything.
    RCO likes this.
  6. bisco
    52,883
    have you contacted other two owners for their experience?
    RCO likes this.
  7. keymusic
    211
    113
    Southern California
    No that isn't necessary. I confirmed that the behavior of mine is the same as other Twos by checking them at a dealership.
    RCO and Prodigyplace like this.
  8. bisco
    52,883
    all the best!(y)
    keymusic likes this.
  9. Prodigyplace
    12,720
    11,852
    Central Virginia
    My 2017 acts like that.
    And, I am sure, there are more than two of us.
    :D
    RCO and keymusic like this.
  10. keymusic
    211
    113
    Southern California
    Yep all of the Twos are not behaving properly.
    RCO likes this.
  11. wrprice
    wrprice Active Member
    415
    308
    Houston, TX
    Four Touring
    Nitpicking, but it should also be used by the auto climate control system. More ambient light should correlate to higher cooling effort, and at night a less aggressive use of the blower fan.
  12. Prodigyplace
    12,720
    11,852
    Central Virginia
    It possibly *could* , but I know the Eco mode of the auto climate control does not vary the fan speed, so I doubt it is used for that.
    RCO likes this.
  13. Mendel Leisk
    42,368
    Sounds like you're on to something, and going through channels, "presenting the case" in a way that should wake them up. Good luck!
    RCO likes this.
  14. bisco
    52,883
    if it's a safety issue, nhtsa will force toyota to fix it.
    RCO likes this.
  15. Prodigyplace
    12,720
    11,852
    Central Virginia
    It would be good to get some response to this from @Prius Team
    Or possibly how to officially present the issue.
  16. bisco
    52,883
    that's the ticket.;)
  17. keymusic
    211
    113
    Southern California
    I might not have a case if it didn't specify on page 98 of the manual that it absolutely is supposed to function this way. And it doesn't say "*if equipped" so it needs to function properly on every trim level with standard features.
    RCO likes this.
  18. wrprice
    415
    308
    Houston, TX
    Four Touring
    It did on my Gen2, my Gen3 Two, and also my '94 Dodge. None of those cars had auto headlights, FWIW. They all had auto climate control.
  19. keymusic
    211
    113
    Southern California
    I thought of contacting the NHTSA but I'm not sure if that'll do anything.
  20. Prodigyplace
    12,720
    11,852
    Central Virginia
    I think all trim lines have the same climate control. Does yours vary the fan speed?
