Instrument Lights - Let's Contact Toyota
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by keymusic, Nov 9, 2016.
  1. keymusic
    keymusic Active Member
    211
    113
    Southern California
    Thanks but I abandoned it because I couldn't get any help from Toyota after countless tries. And it's really not the most important thing to me. But my Crusade was certainly not hopeless or ill planned.
  2. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Didn't mean to sound snarky.
    I personally love a hopeless cause.
    I'd charge that windmill...until the sunset and my dash lights dimmed.
    pilotgrrl, Mendel Leisk and keymusic like this.
  3. RRxing
    RRxing Senior Member
    2,564
    1,842
    NEPA
    Didn't read through the entire thread, but on the Gen III, the light sensor on the dash is part of the climate control system, mainly to adjust blower speed based on light intensity. It has nothing to do with dimming the instrument cluster lighting. This may have changed on Gen IV, so I won't speak to that...
  4. keymusic
    211
    113
    Southern California
    Sorry but that's not correct. The ambient light sensor may be part of the climate system, but it also worked to keep the instrument lights bright if you turned on the headlights and it was bright outside. I had a 2013 & 2015 Two model and it worked that way in both of them. That's why I was disappointed to find out my, and all other, 2017 Two models don't do this. If my gen 3's didn't do that, I never would've even known about it. And just to reiterate, I checked a 2017 Three model, and it did work. And the reason I said earlier I had a 2011 and 2015 model is because I actually had a 2011, 2013, and 2015 all Twos. I think it's possible that the 2011 did not to do this, but the 2013 and 2015 definitely did.
    #44 keymusic, Aug 9, 2017
  5. bisco
    52,883
    do you think toyota purposely cut out some parts to save money on the II?
  6. keymusic
    211
    113
    Southern California
    I doubt it since the light sensor is there and I can't imagine the electronics to run it would've been very expensive. It just seems like some very strange oversight, especially since it does specify in the manual that it does have that feature.
  7. bisco
    52,883
    if you need the sensor for climate, can't lose that. maybe somethings disconnected or programmed incorrectly, but why only II?
  8. keymusic
    211
    113
    Southern California
    I know, it doesn't make any sense. And by the way other than some people saying it, I honestly don't know anything about the ambient light sensor having anything to do with the climate control system in a 2017 Two.
  9. bisco
    52,883
    me neither.
  10. Prodigyplace
    12,720
    11,852
    Central Virginia
    Not likely something disconnected. The dash lights on my 2017 Two also dim when headlights are turned on during the day.
  11. RRxing
    2,564
    1,842
    NEPA
    I'll only speak to the 2010 IV, but I won't have access to my reference materials until tonight...
  12. RRxing
    2,564
    1,842
    NEPA
    From the 2010 New Car Features...
  13. liquidtenmillion
    liquidtenmillion Active Member
    261
    194
    Easley, SC
    I can vouch for the climate system being effected by the light sensor, in both my 2015 and 2017.
    If I am sitting in my garage running the AC and then drive the front of the car out about 3 seconds after the light sensor is exposed to light the fan speed will increase. Back it into the garage and it will decrease again after a few seconds.
    #53 liquidtenmillion, Aug 11, 2017
    RCO likes this.
  14. keymusic
    211
    113
    Southern California
  15. RRxing
    2,564
    1,842
    NEPA
    It's not referencing a solar panel...
  16. keymusic
    211
    113
    Southern California
    I assumed "detects the changes in the amount of solar energy and outputs them to the air conditioning amplifier assembly" was referring to the solar energy coming from the solar panels. Is it referring to solar energy coming from the sun?
  17. Prodigyplace
    12,720
    11,852
    Central Virginia
    No US Gen 4 Prius have a solar panel option. It adds too much weight, I suspect.
    keymusic likes this.
  18. RRxing
    2,564
    1,842
    NEPA
    It's referencing the amount of solar energy impinging on the "Automatic Light Control Sensor" on the dash, which sends a signal to the air conditioning amplifier, which automatically adjust the climate control blower speed. Bright, sunny day, more air flow, cloudy day, less air flow (assuming you leave the climate control system in Auto.)
    RCO likes this.
  19. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    In my Gen 4, the ambient light sensor will dim the instruments only if the instrument illumination setting is not on max brightness. Setting the illumination to full overrides the sensor.
    pilotgrrl and RCO like this.
  20. Prodigyplace
    12,720
    11,852
    Central Virginia
    I told my salesman I thought their placement of the inspection sticker is partially blocking my sensor. He said they had no issues with that. I will try to have it relocated in October when it is replaced.
    RCO likes this.
