Instrument panel problem
Discussion in 'Gen 3 Prius Main Forum' started by Katherine28, Oct 28, 2018.
  1. Katherine28
    Katherine28 New Member
    Newport, Oregon
    2011 Prius: Why is it that when I turn on my running/ headlights my instrument panel darkens? It doesn't go out but it is hard to see. Is there an adjustment?
  2. Tideland Prius
    16,650
    Yes. Look for the rotary dial to the left of the steering wheel, on the dashboard.
  3. AzWxGuy
    AzWxGuy Weather Guy
    1,077
    554
    Tucson, AZ
    2021 Prius
    And if you roll the dial completely in direction 1 you will encounter a detent where the instrument panel will be full daytime illumination. That is where I set it when driving in inclement weather during the day with headlights on.
  4. MCCABE Yohe
    MCCABE Yohe New Member
    22
    16
    York, PA
    Did you try this fix? I have mine rolled all the way in the direction of 1 and then you can push it a little further and it clicks in a super bright mode...that is where I keep mine!
