Intake Air resonator is gone: replace or not?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by oxnardprof, Apr 22, 2025.
  1. oxnardprof
    oxnardprof Member
    250
    17
    Oxnard, CA
    My daughter hit a couch that fell off another vehicle.
    She was able to get most repairs done, but the mechanic did not replace the intake air resonator.
    (Part number is 17893-21030).
    I have read through various posts here, and my impression is that it does not need to be replaced, that there will be increased engine noise, but no harm to the car.
    Also, minimal risk from water getting into the engine air filter.
    The car is a 2004 Prius with over 200000 miles, running well otherwise.
    Any ideas on labor cost (number of hours)?
  2. PriusCamper
    PriusCamper Senior Member
    13,467
    5,435
    Pacific Northwest, USA
    It's a really easy part to replace and you'll be able to practice on a vehicle at a wrecking yard when you remove it. And I agree that its not an issue to drive without it, but using a wrecking yard to replace whatever is missing or broken will heavily influence your decision in the future when the car needs expensive repair work.
    As in the people who give up on their vehicle when an expensive repair happens are usually the ones that don't fix all the little things or keep their car clean. Where as those who do that, will be more likely to spend for the expensive repair and keep their car on the road for years to come that because its only one expensive thing wrong with the car, not a long list of things.
  3. BiomedO1
    BiomedO1 Senior Member
    4,625
    2,425
    Left Coast
    This may become an issue during the cars' smog inspection; if the inspection station realizes it's missing. Missing pieces or aftermarket equipment under the hood, usually triggers a closer inspection. If there's a question, most smog stations will simply fail it - rather than place their license to operate in jeopardy.
    I'd visit a junk yard and pull the entire assembly; just in case. It's just a couple of screws and clamps or have whomever repaired the car take care of it.
    Good Luck....
    #3 BiomedO1, Apr 22, 2025
