Intake Camshaft Positioning Sensor Wiring
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Logan Mace, Sep 30, 2022.
  1. Logan Mace
    Logan Mace New Member
    West Virginia
    Hey all, any help is appreciated. I have been looking for the harness plug diagram, or pinout, for the intake cam positioning sensor. I need to know where the red, white and black wires are positioned in that connector.
    The wires pulled free from the connector, and I even went to the Toyota dealership who said they’d get back to me as soon as they can to get me that info. Still don’t have it.
    I’ve seen some images, but either wires are different color or not identifiable. I have red (assume VCC), Black and White (signal?). But, where are they positioned in the connector?
  2. 419 Grease Monkey
    419 Grease Monkey New Member
    Houston, TX
    My 2012 has Red, White, Black from bottom to top when the mount is facing you.
  3. ChapmanF
    15,533
    Notice the pin numbers shown out of order; in order would be VVI+, VVI−, VC.
      File size:
      2.6 KB
  4. 419 Grease Monkey
    Houston, TX
    That seems to be how mine is, black = 1, white = 2, red = 3 looking at the harness connector face with the latch up.
    Any info on what the resistances or voltages should be? I have 4.9V on 2 pins with ignition in "on". resistance of 1200 Ohms on sensor.
