Intake manifold cleaning
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Eddy Connelly, Nov 8, 2018.
  1. Eddy Connelly
    Eddy Connelly Member
    37
    27
    New York
    Hey guys,
    I'm planning on cleaning my intake manifold on my 2010 gen 3 prius which is approaching 150k. My question is, since theres coolant lines involved, should I also drain and replace the engine coolant during the cleaning? I wanted to replace the coolant anyway, and I figure it would make sense to do it at the same time. Just curious if there is a reason I shouldn't do it at the same time as cleaning the intake manifold.
    Raytheeagle likes this.
  2. ASRDogman
    ASRDogman Senior Member
    8,042
    4,075
    If you were planning on changing the coolant anyway, go for it! :)
    Robertto09 likes this.
  3. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    I would also do the egr cooler
    m.wynn and Raytheeagle like this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Perfect time to do it:).
    Every time I clean the egr circuit, I changed the coolant ;).
    Keeping the engine coolant fresh I feel is another key to success at high mileage(y).
    m.wynn likes this.
  5. Mendel Leisk
    42,260
    If you're just doing the intake manifold, you need to remove the throttle body, but there's no need to disconnect it's coolant lines. They can remain connected when you lift the throttle body off.
    If you're doing the EGR you do need to disconnect coolant lines, but if you drain a couple of liters into a clean container before starting, the coolant level will drop below the EGR components. Just be careful when lifting the cooler off, there's a little bit of coolant trapped at the lower back corner.
    After the EGR is reinstalled, pour the drained coolant back into the reservoir. It'll be a little high, but should settle back to normal with a bit of driving.
    Eddy Connelly likes this.
  6. Eddy Connelly
    37
    27
    New York
    Hmm so glad I asked! I was planning on cleaning the egr pipe in a separate round, being that it seems a little tricky and time consuming. Is the egr cooler different from the egr pipe?
  7. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Yes;).
    The cooler is composed of many small fins where the carbon deposits collect, making this easier than the pipe to clog:(.
    I’d add that to the list for cleaning(y).
  8. Mendel Leisk
    42,260
    Here's the EGR components:
    Watch @NutzAboutBolts videos, pinned at top of 3rd gen Maintenance sub-forum. There's one for just cleaning the pipe, and another for cleaning the complete EGR system. (Yet another for intake manifold cleaning.)
    Also read through this thread on EGR cleaning, lots of info:
    EGR & Intake Manifold Clean Results | PriusChat
    Some relevant Repair Manual excerpts attached:
    #8 Mendel Leisk, Nov 9, 2018
  9. Eddy Connelly
    37
    27
    New York
    Thanks guys! I wanted to do the intake manifold and egr cleaning as separate items, being that I want to take my time and not get stuck in the limited daylight we have now in the fall. This definitely helps determine that i could do the intake manifold without the coolant replacement, then do egr with coolant replacement on another day.
  10. Mpdcnva
    Mpdcnva Member
    51
    27
    Washington dc
    Four Touring
    Ok guys. I have the instant cleaner for the intake and cooler. You HVAC guys will be smacking your head, but Nu Calgon, evaporator cleaner made my intake and cooler crystal clean after soaking for an hour. For you non HVAC guys, this cleaner is what your AC guy uses to clean your outdoor AC unit. I used NuBrite, the blue stuff mixed 3 to 1. Incredible results; soak, rinse, done. The cleaner was black and the intake and cooler look like new.
  11. ASRDogman
    8,042
    4,075
    Where did you get it? What does it cost?
  12. Mendel Leisk
    42,260
    Interesting, here's a link:
    Nu-Brite Nu-Calgon
    Description says it's alkaline. Accordingly I'd say no problems using it on EGR cooler which is 100% stainless steel , but on intake manifold if you use rinse VERY well. I'd be cautious using it on EGR valve, which is mostly aluminum, and has some electrical internals.
    Alkaline cleaner residue can react with ferrous bolts, inserts. And alkaline dulls aluminum quickly.
    My 2 cents, just use on cooler, and use brake cleaner on the rest.
    Mr. F, Paul E. Highway and Merkey like this.
