Intake Manifold Gasket Prep
Discussion in 'Gen 2 Prius Main Forum' started by Friedenmeister, Feb 26, 2018.
  1. Friedenmeister
    Friedenmeister Junior Member
    Hi Guys,
    I will be swapping out the intake manifold gasket on my 2008 tomorrow and just wanted to get your feedback on how to prep the gasket. I have a factory OEM replacement gasket, which is made of metal with a coating on it. I was wondering if the proper way to install one of these gaskets is to run a very light very thin coating of RTV around it on both the head and manifold sides, or if I should run a little oil around it, or if I am good to just put it on and go?
    Thanks in advance,
    Fried
  2. DMC-5180
    DMC-5180 Active Member
    294
    134
    Can you post a close up photo of the new gasket?
    Just curious what you paid for the gasket? List price from toyota is $225 (ridiculous)
    Btw, the their is a maximum warpage spec on the manifold of 0.0039.
    I have access to factory service info, but for some ODD reason. I was not able to find any procedures or torque specs for the intake manifold installation.
    Exhaust, yes
    Head, yes
    Intake, no
    Throttle assembly, yes
    Weird.
    I would not put anything on that gasket.
    iPhone X ?
  3. DMC-5180
    294
    134
    Correction: intake gasket $7.20 from toyota
    The $225 was the manifold itself.
    The Beaded steel gasket is not meant to have any other compound on it.
    iPhone X ?
    Prodigyplace likes this.
  4. Prodigyplace
    12,712
    11,848
    Central Virginia
  5. DMC-5180
    294
    134
    I dug pretty deep, nothing is listed for Intake to cylinder head. I found the stud installation driving torque of 7.1 ftlb. It likely just falls under general torque specifications for the stud size class and thread pitch in combination with nut classification.
    I don’t know the stud size. M6 x 1.00 or M8 x 1.25
    iPhone X ?
  6. Prodigyplace
    12,712
    11,848
    Central Virginia
    OK, thanks.
    I know you have been around here for quite a while but I had not seen enough of your postings to determine your attention to detail. Thank you for your help here.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Dry gasket.
  8. edthefox5
    10,096
    4,837
    Clearwater, Florida
    And new bolts.
  9. Mendel Leisk
    42,343
    Here's some info from second gen Repair Manual, snapshot, and same thing attached as pdf.
    Prodigyplace and edthefox5 like this.
  10. DMC-5180
    294
    134
    Where was that illustration located. It’s not shown in my cylinder head info thru my Alldatadiy subscription.
    iPhone X ?
  11. edthefox5
    10,096
    4,837
    Clearwater, Florida
    #11 edthefox5, Feb 26, 2018
  12. Prodigyplace
    12,712
    11,848
    Central Virginia
    But they are working on the intake manifold.
    edthefox5 likes this.
