Intake manifold off: does this look like busted EGR cooler?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bdc101, Sep 30, 2023.
  1. bdc101
    bdc101 Member
    250
    usa
    Cylinder 4 is wet, but the other cylinders are mostly dry (a little oily is all). Cylinder 4 port is pictured. PXL_20231001_023318326.jpg PXL_20231001_023418316.jpg PXL_20231001_023341356.jpg
    I bought the car as a fixer-upper. 262k miles and PO had a mechanic diagnose a misfire as a leaky HG. Does this look like it could just be the EGR cooler or does this EGR cooler look healthy (other than probably never having been cleaned)? Or do I need to clean it real good first to tell... Thanks in advance.
    (TB is pictured as well, note that it is only wet because I failed to drain the coolant out of it first...otherwise quite clean)
    #1 bdc101, Sep 30, 2023
  2. bdc101
    bdc101 Member
    250
    usa
    Cylinder one: PXL_20231001_023357584.jpg
  3. tony_2018
    tony_2018 Member
    227
    68
    not a busted egr
  4. Tombukt2
    Tombukt2 Senior Member
    13,844
    2,515
    Durham NC
    Yes that EGR cooler the silver piece is very clogged You need to have that professionally cleaned That's what I do is cheaper to me to drop it off at the machine shop and let them tank it or the radiator shop whatever or you can do what other people do and clean it in various and sundry solutions I'm usually pretty busy I know the guys at the shop I just drop them off and pick them up couple of days later all nice and clean and ready to go The inside will be a parkerized gray looking finish when it's cleaned properly It is a horrid design part really bad It can do nothing but clog giving the connections made to it. You need long bristle brushes to clean the connections from the EGR into the intake ports those little small holes. And then the long hole that runs from the metal tube all the way down the plastic manifold You want to make sure that is clear Free flowing etc.
  5. Mendel Leisk
    42,310
    Better deal with the head gasket first.
  6. bdc101
    bdc101 Member
    250
    usa
    copy, thanks all! Will get started taking the head off today.
  7. Mendel Leisk
    42,310
    They must be using something pretty nasty to take off the stainless steel sheen. I’ve cleaned ours a couple of times using Oxi-clean soaks, just looks like new.
  8. bdc101
    bdc101 Member
    250
    usa
    How do I clean the valve, by the way?
    I made the mistake of taking the cover off the valve (the black part) but I think I got it back on correctly.
  9. bdc101
    bdc101 Member
    250
    usa
    Forgot to upload the pic
  10. Mendel Leisk
    42,310
    I’d just use brake cleaner (or “parts cleaner”?), some sorta petroleum solvent, with rags and brushes. The housing is aluminum so avoid corrosive/alkaline cleaners (oxi-clean, oven cleaner, purple power); while “maybe” not detrimental they will react with aluminum, turn it dull grey. Be careful not to get sprays in the electronic housing, just in case.
    bdc101 likes this.
  11. Mendel Leisk
    42,310
    A well exposed pic of the cooler interior would be interesting. Shining some sort of pen light on helps.
    Actually that one you posted is not bad; near-totally occluded...
    How did the EGR passages on the intake manifold look? The red arrows:
    ^ Kinda telling, this is just a stock picture when I googled (prius intake manifold egr), popular topic. :rolleyes:
    #11 Mendel Leisk, Oct 1, 2023
    Tombukt2 likes this.
  12. Tombukt2
    13,844
    2,515
    Durham NC
    That's what I was looking at and one of his first pictures was a picture of what that port mates up to on the head and looked pretty nasty. So I was wondering about the ports in the intake
  13. bdc101
    bdc101 Member
    250
    usa
    Will go take some pics in a bit. I didn't know that was where the EGR entered the manifold, so I will inspect it closely and take some better pics.
  14. Mendel Leisk
    42,310
    A lot of that port crud comes from the PCV I think. But yeah the EGR contributes as well.
  15. Mendel Leisk
    42,310
    Those narrow EGR passages in the intake manifold tend to clog sequentially, commencing with cylinder one passage being the first to totally plug. That's the cylinder where head gasket failure begins, specifically at the wall between cylinders one and two.
  16. rjparker
    rjparker Tu Humilde Sirviente
    11,059
    6,928
    Texas Hill Country
    Did not know I had a level of cooler finish named after me. The first one I did was totally clogged with hard gunk from front to back. While I replaced that one for expediency, it took several on off days with a cost hanger wire chucked up to a drill to see light through it. I like Tom’s strategy much better.
    #16 rjparker, Oct 1, 2023
  17. bdc101
    bdc101 Member
    250
    usa
    More pics as requested! I appreciate all the responses.
    All the fuel injectors are very dirty too. But under the valve cover looks amazing for a motor with 262k miles! PXL_20231001_221846930.jpg PXL_20231001_221709110.jpg
  18. bdc101
    bdc101 Member
    250
    usa
    VC
    mikey_t likes this.
  19. rjparker
    11,059
    6,928
    Texas Hill Country
    Somebody changed the oil religiously but the rings are causing a lot of carbon.
    mikey_t likes this.
  20. Mendel Leisk
    42,310
    Is that intake manifold EGR passage at cylinder one? It looks not bad at all, for those miles. Maybe the intake’s been cleaned before.
