Intake Manifold torque specs?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by palmer976, Dec 21, 2013.
  1. palmer976
    palmer976 Junior Member
    24
    46
    North Carolina
    Any chance anyone knows the intake manifold torque specs for the 2010 Prius?
    Thanks in advance for the info!
    Greg
    288k 2010 Gen iii
  2. frodoz737
    frodoz737 Top Wrench
    4,810
    2,562
    33
    INSTALLATION
    1. INSTALL INTAKE MANIFOLD
    (a) Install a new No. 1 intake manifold to head gasket to the intake manifold.
    (b) Install the intake manifold with the 2 bolts and 2 nuts. Torque: 28 N·m (285 kgf·cm, 21ft·lbf)
    (c) Connect the fuel vapor feed hose and ventilation hose.
    (d) Install a new O-ring to the engine oil level dipstick guide sub-assembly. (e) Apply a light
    coat of engine oil to the O-ring.
    (f) Install the engine oil level dipstick guide sub-assembly with the 2 bolts and connect the wire
    harness clamp.
    Bolt (A) - Torque: 28 N·m (285 kgf·cm, 21ft·lbf)
    Bolt (B) - Torque: 21 N·m (214 kgf·cm, 15ft·lbf)
    (g) Install the engine oil level dipstick.
    (h) Connect the 2 wire harness clamps and 3 connectors.
    2010 Toyota Prius
    Repair Manual
    2. INSTALL VACUUM SWITCHING VALVE ASSEMBLY
    3. INSTALL MANIFOLD ABSOLUTE PRESSURE SENSOR
    4. INSTALL EGR PIPE ASSEMBLY
    5. INSTALL THROTTLE BODY ASSEMBLY (a) Install the throttle body assembly
    2010 Toyota Prius
    Repair Manual
    Sorry the illustrations are missing, but if your got this far, you probably have it handled. Bolt (A) is the upper harness clamp and (B) is the lower one.
  3. palmer976
    24
    46
    North Carolina
    Thank you, very much appreciated.
