Intake temperature sensor
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dfairch69, May 18, 2023.
  1. dfairch69
    dfairch69 Junior Member
    38
    Ohio
    I have a 2008 Prius and was wondering where the intake temperature sensor is located? I am doing annual tune up and came across this section on a forum talking about the intake temperature sensor and I have never changed it. I have changed the maf sensor but not this one. Thank you.
  2. ChapmanF
    18,959
    It's combined with the MAF sensor (it's the bulbous thing you see on the side), so if you changed that, you changed 'em both.
    That said, I can't think offhand of many reasons it'd ever need to be changed. Nothing much happens to thermistors, that I know of.
  3. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Best to just clean it with "MAF cleaner", then attack the throttle bore and buttery fly valve with a toothbrush dipped in rubbing alcohol or vodka.
    Link to said section?
  4. dfairch69
    38
    Ohio
    Thank you. I was thinking it was the maf sensor.
  5. dfairch69
    38
    Ohio
    Thank you.
  6. ChapmanF
    18,959
    Not uncommon. The mass airflow is sensed by the two very fine wires that you can barely see if you look deep into the tunnel in the sensor body.
    And then there's the bulbous thing right there in your face on the outside, which people often think is the MAF sensor, but it's the thermistor for the intake air temperature.
  7. PriusCamper
    PriusCamper Senior Member
    13,405
    5,412
    Pacific Northwest, USA
    So that's what happened to my bottle of vodka...
