Intake valves .001" too tight - worth adjusting?
Discussion in 'Gen 2 Prius Technical Discussion' started by jeremy3s, Aug 17, 2019.
  1. jeremy3s
    jeremy3s Junior Member
    I pulled the valve cover off my 2nd gen to replace the gasket since oil was leaking in the spark plug holes. While I was in there, I decided to check valve clearance. I found 4 of the intake measurements to be tighter than spec. Each of the 4 measured 0.006" while spec is .007-.009".
    Is .001" too tight worth the time and effort to adjust them into the proper range?
  2. Mendel Leisk
    42,293
    How many miles? And was it stone-cold?
    Here's some repair manual excerpts. I haven't really looked close; if there's more you need let me know, I could look some more:
    #2 Mendel Leisk, Aug 17, 2019
    jeremy3s likes this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    You could probably have 10 people check clearance and you would get 7 different answers. For situations like this, a good friend once told me....
    IIWW, LITFA
    If It Was Working, Leave It The Xxxx Alone..............
    edthefox5 and Zeppo Shanski like this.
    52,803
    hey, if you're already in there, why not?
    TMR-JWAP likes this.
  5. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    Yeah....kind of like, since I have the refrigerator door open to get a drink, I may as well make a sandwich. Just maybe a thousand times harder....and a single stupid (or unlucky) move could put the car OOC for a week or more......:whistle:
  6. bisco
    52,803
    true but it is out by .001. that's nothing to sneer at. and what's wrong with a sandwich?
  7. ChapmanF
    18,974
    Gen 2 has the 1NZ engine. Here's a post to give you an idea of the process for adjusting 1NZ valve clearance.
    You can replace the engine with a lower-mileage one in a fraction of the time and effort.
    NortTexSalv04Prius and wnrsm like this.
  8. bisco
    52,803
    but what a great learning opportunity
  9. Mendel Leisk
    42,293
    It's a far-cry from the screw and lock nut adjusters on Hondas, pretty much a top-end tear-down.
    wnrsm likes this.
  10. bisco
    52,803
    i spent a lot of time adjusting my '74 fiat valves. it's an experience of a lifetime
  11. Mendel Leisk
    42,293
    Simple adjusting screws?
    With our old Accords, the valve cover was very accesible: take off it's hold-down bolts, disconnect a hose or two, pry a bit, and you're there.
    Then get out eh Shop Manual, and put a ratchet and socket on the crankshaft, through the wheel well.
    With the screw and lock-nut adjusters, 2~3 hours is all it would take.
  12. bisco
    52,803
    lock nuts iirc, it's been 40 years :oops:
    Raytheeagle and Mendel Leisk like this.
  13. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Well actually it probably IS nothing worth worrying about.
    Being a hair too tight indicates that the valves are seated .001 farther down in the seat than the minimum spec.
    They could have been that way for a LONG time......maybe even since the engine was built.
    It is fairly common for them to tighten up a bit with age......since the valve face and seat usually wears more than the cam lobes and valve stem.
    I vote for leaving them alone.....and checking again in another 50K miles or so.
    Edit: And given what has been said in the last few posts about the procedure necessary, I wouldn't have checked them in the first place.
  14. jeremy3s
    I decided to go ahead and do the job over the weekend. There was a set of old lifters from a warped head laying around in the garage. Using those, I was able to get all the 4 intake valves in spec. This was my first time doing a valve adjustment on one of these, so I did have to pull the cams a second time to get everything right. In the end i think it was worth it.
    The engine has 292k miles on it, so should be good to go for at least another 100k.
    bisco and SFO like this.
  15. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    IDK what to even say..............I'll make sure to look you up for advice next time I want to make my life 100x more difficult than it needs to be....... ;)
    But...well done..you have my respect for being willing to tackle that job
  16. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    How long did it take you?
  17. jeremy3s
    I have a habit of making things harder than they have to be. But, I'd say I only made it 10x harder than it had to be. lol
  18. jeremy3s
    I'd estimate I spent 10-12 hours working on it. But, I double and triple checked things. This included 2x of pulling and installing the valve cover, the cams, and making sure the timing was right. I also drew pictures, and took a lot of measurements. If it's your first time and you want to start the job on a Saturday and absolutely need the car on Monday, I wouldn't recommend it. If you don't have a set of used lifters available you'll be ordering those on Monday. And even if you do have a set, there's no guarantee you'll be able to get everything in spec with them.
  19. bisco
    52,803
    i'm not sure, but you may be the first!(y)
  20. Mendel Leisk
    42,293
    Yeah that's commendable.
