Intake valves .001" too tight - worth adjusting?
Discussion in 'Gen 2 Prius Technical Discussion' started by jeremy3s, Aug 17, 2019.
  1. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Assuming that everything went back together properly, there probably was a lot of learning accomplished here.......even if nothing else useful was.
    Back about 1965, I took apart the top end of my 283 Chevy to "fix" an assumed clicking lifter.
    I learned a LOT......including not to sit a carb in your lap while it still has gas in it !!!
    Also learned that what appears to be obvious and a natural assumption is not always correct.
    My clicking noise turned out to be a broken fuel pump spring.
  2. ChapmanF
    19,054
    There was a commencement speaker at my college who told us "in a choice between ways of doing something, pick the one that will teach you more."
    Every now and then I've had moments I'll describe it as a curse....
    Raytheeagle, Mendel Leisk and JC91006 like this.
  3. sam spade 2
    7,035
    2,804
    2017 Prius c
    But there are all KINDS of valuable things that you should learn.
    Right near the top of the list should be:
    Don't waste time and money learning something that you will never need to apply ever again.
    Good time and money management is the basis for a LOT of other learning.
  4. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    What if car care is the guys hobby? People spend great amounts of time on their hobbies all the time. It’s comments like that that show why you are on so many peoples ignore lists.
  5. sam spade 2
    7,035
    2,804
    2017 Prius c
    Yes I understand that a lot of people don't like to hear things that go against their opinions.
    And some people have a problem with reading comprehension and see fighting words when there are none.
    Their loss.
  6. Skibob
    2,912
    1,505
    Northern California
    The door swings both ways Sam. Plenty of posters here have told you to F-OFF. You think its all of them and not you? Perhaps you should take lessons in writing comprehension, you would be better served.
  7. sam spade 2
    7,035
    2,804
    2017 Prius c
    Or not.
    A reaction like that often proves that they understand what I have said PERFECTLY.
    (y)
  8. Zeppo Shanski
    Zeppo Shanski Active Member
    315
    193
    Chicagoland
    .001 ... Seriously?
  9. bisco
    52,891
    wouldn't bother until .002
  10. Zeppo Shanski
    315
    193
    Chicagoland
    This would be a perfect time for Marvel Mystery Oil ... to do it's only real job ... that it does very well (cleaning rings and/or valves).
  11. sam spade 2
    7,035
    2,804
    2017 Prius c
    Tight valves indicate WEAR has already occurred.
    No amount of "additives" will reverse that process.
  12. Zeppo Shanski
    315
    193
    Chicagoland
    OK.
    Additives clean away carbon build-up. My only problems with valves has been with carbon build-up. I guess I spoke a little fast.
    #32 Zeppo Shanski, Aug 27, 2019
  13. sam spade 2
    7,035
    2,804
    2017 Prius c
    Typically the carbon "buildup" on valves does NOT really indicate any kind of a problem.......despite what "shake oil" companies would have you believe.
  14. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Wish you could've documented, or shared your journey here for those that will come after you.
    Any residual tricks of the trade that are worth imparting on the rest of us?
    Raytheeagle likes this.
  15. Zeppo Shanski
    315
    193
    Chicagoland
    Carbon build-up affects the way air enters the combustion chamber, causing many symptoms, including but not limited to: misfiring, rough running, hard starting, and poor fuel economy. Worse yet, the likelihood of a burnt valve is drastically increased.
    But then again ... I could be wrong. ... And I'm sure you're gonna tell me.
    Skibob likes this.
  16. sam spade 2
    7,035
    2,804
    2017 Prius c
    Yes you are totally wrong.
    Carbon on the FACE of a valve has almost no impact on the incoming air flow, since that happens around the seat on the edges.
    And valves "burn" because they don't seat right.....and for carbon deposits to cause that, it would have to be REALLY BAD.
    Unless there is another long term obvious problem that you have been ignoring, there will never be that kind of carbon in the combustion chamber of a modern engine.
    Marketing is 95% lies.
    The 5% is when they make a mistake and accidentally tell the truth.
    But if it makes you feel good to dump "snake oil" into your engine, then go right ahead.
    The odds are about 50/50 that it will CAUSE more trouble than it fixes though.
  17. Skibob
    2,912
    1,505
    Northern California
    Use the ignore feature under his name and that all goes away.
    Zeppo Shanski and Raytheeagle like this.
  18. ChapmanF
    19,054
    Oh man ... you don't bring Open Sans 22 point to a font fight.
    edit ... this post can now be a perpetual little puzzle in memory of the now-vanished post that inspired it...
    #38 ChapmanF, Aug 29, 2019
  19. Frogblast
    Frogblast Junior Member
    CA
    Since you were in there to do the adjustment: do you really need the SST that the manual says is needed to loosen up the camshaft / camshaft gear? Or is there another more readily available tool that gets the job done?
    SFO likes this.
  20. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Just curious not understanding this but how do the valves get tighter with wear?
    No hydraulic lifters.
    The fixed shims or buckets wear out thereby loosening the contact with the cam lobe thereby creating more valve tick. Cam lobe wears then less contact more clearance. All contact has greater clearance then.
    How do I get less clearance with wear?
