Intake valves .001" too tight - worth adjusting?
Discussion in 'Gen 2 Prius Technical Discussion' started by jeremy3s, Aug 17, 2019.
  1. Mendel Leisk
    42,369
    I never saw less clearance, always more. But I think the idea is that valve seats wear; the valves are able to ride higher.
    edthefox5 likes this.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    But valve seat wear means the valves are going deeper into the head which is more clearance on the shims.
    Never heard of my valves are tight from wear.
  3. Mendel Leisk
    42,369
    As the seats wear the valves would rise, valve stem tips would be higher? Again, in practice I've never had this happen.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    When the valve seat and matching face actually wears.
  5. sam spade 2
    7,035
    2,804
    2017 Prius c
    No it is NOT.
    Once again, you aren't thinking straight.
  6. Mendel Leisk
    42,369
    Maybe a visual aid would help:
    Spring is constantly trying to pull the valve up. What stops it is the valve seating against the port opening. As the valve and/or seat wear, the valve moves up.
    NortTexSalv04Prius likes this.
  7. sam spade 2
    7,035
    2,804
    2017 Prius c
    Tighter against the cam or rocker arm......which is not shown in the diagram.
