Intelligent clearance sonar reprogram MPG ?
Discussion in 'Gen 4 Prius Main Forum' started by rosencrantz, Apr 7, 2019.
  1. rosencrantz
    rosencrantz Member
    97
    77
    Central Valley, CA
    2018 Prius
    Hello, I recently took my Prius in for its 6 month checkup with 3500 miles on the clock. I asked the dealer to perform any recalls while it was in for service and they informed me that it needed the ICS reprogram. This was a couple days ago. Today, we took the car on a little 200 mile road trip to Santa Cruz and I noticed something very specific. The car spent less time in “EV” mode at cruising speeds (60 - 70mph) than I believe it did prior to the ICS reprogram. Is this “normal”? Does the car have to “relearn” optimal MPG after a reprogram?
    Thanks much to all you Prius experts!
    Oh... prior to the ICS reprogram, the car typically gave an “indicated” 58 mpg. The trip to Santa Cruz gave an indicated mpg of approximately 52.
    #1 rosencrantz, Apr 7, 2019
  2. krmcg
    2,592
    2,390
    Whittier, CA
    Check your tire pressure. Dealers often lower the pressure which lowers the MPGs.
    Tyfly likes this.
  3. rosencrantz
    rosencrantz Member
    97
    77
    Central Valley, CA
    2018 Prius
    Thank you. That’s a good idea.... I usually make it a point to keep the tires at 34 - 36 PSI.
    krmcg likes this.
  4. jerrymildred
    jerrymildred Senior Member
    11,518
    14,127
    Tampa, FL
    Tires are a possibility for sure. Also, the reprogramming may have caused the car to forget a lot of stuff specific to your driving. It may come back up in a few days or weeks.
    will the engineer likes this.
