Intelligent Drive Coach
Discussion in 'Prime Fuel Economy & EV Range' started by mr88cet, Feb 22, 2017.
  1. Dmitriy Sokol
    Dmitriy Sokol Active Member
    112
    108
    Annapolis, MD
    Enabling those green leafs and the PED in the Nav POI system is purely for display purposes. The green leafs will show you where the car will engage extra regen force. The system will work anyway, even if you disable the visual. I turned off the leafs after a while, because they cluttered my map, but PED works just like it did.
    Predictive traffic is a whole other story. It's a useless feature that tells you if an area will have traffic, based on historical data. It's almost always wrong in my experience.
    Optimus PRIME likes this.
  2. Optimus PRIME
    Optimus PRIME Active Member
    180
    141
    SF Bay Area
  3. KyLien
    KyLien Junior Member
    27
    35
    Whittier, CA
    PED will work once you enable it regardless if you enable the green leafs or not. However you turn off PED using the step I have outline above. Your eco score will be skewed if you have PED enabled because the SW seem a bit buggy in predicting when you should/shouldn't ease off on your accelerator pedal.
  4. mdhare
    mdhare Member
    59
    33
    Madison, WI
    So, I have a Premium with not many miles on it yet (7 days, ~200 miles). The Navi manual pg 259 says go to menu -> settings -> navigation -> detailed navi. settings. I do not have a box 7 (Predictive Efficient Drive). Anyone else with a young premium want to report on their findings? Trying to determine if this isn't available until after you've driven around for awhile, if I don't see it because I'm in a garage (no GPS?), etc..
  5. mdhare
    mdhare Member
    59
    33
    Madison, WI
    responding to self ... I should note that I tried this with car in ACC and ON but not in READY, I'll check that next time I'm on the road.
  6. Tideland Prius
    16,634
    You're in the a different menu. If I'm not mistaken, the screenshot on the first page is found by going back to your main nav screen and pressing "Options" near the top left. That should bring up the same screen that you see on the first page.
  7. mdhare
    mdhare Member
    59
    33
    Madison, WI
    Understood, but KyLien's second snapshot with menu bar "Map Navigation", as I understand, toggles what is displayed on the map, not whether or not PED is enabled/disabled.
    Still haven't gotten out of the garage to check.. :)
  8. Tideland Prius
    16,634
    Oh yes you're right. I'm sorry, I misread your intentions. My apologies.
  9. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    Is the predictive efficient drive just a better version of the one in the gen 4? The one in my car is almost useless TBH
  10. xtins
    xtins New Member
    26
    US
    Perfect thank you so much? May I ask you one more thing? My map won't go black like yours...how can I do this? I have a prime advance model 2017. Thank you. This has been helpful.
  11. Dmitriy Sokol
    112
    108
    Annapolis, MD
    I had the same issue. Go to Menu-display and uncheck Day Mode option. Boom! Your map will go dark and your Prius icon will turn on headlights on top of the screen when your actual lights are on.
    iPhone ?
  12. xtins
    xtins New Member
    26
    US
    Wow! Really? So tonight will be dark if I uncheck that????
  13. Dmitriy Sokol
    112
    108
    Annapolis, MD
    Yes. You can manually turn on your headlights to check if it worked.
  14. xtins
    xtins New Member
    26
    US
    I don't know why isn't working...(?) :(
  15. Dmitriy Sokol
    112
    108
    Annapolis, MD
    Huh? My only guess is that the system does rely on an input from a light sensor and won't activate the dark mode until it's actually dark outside.
    iPhone ?
  16. bisco
    52,595
    same thing, afaik. if you're an experienced hyper miler, it may not help much.
    'LectroFuel likes this.
  17. Dmitriy Sokol
    112
    108
    Annapolis, MD
    I find it useful, but I am not an experienced hypermiler. This is my first Prius. It's not always accurate and doesn't seem to be terrain-aware, despite being GPS-linked. It keep telling me to decrease acceleration as I am trying to climb a steep hill. Still, most of the time it does what it should.
    iPhone ?
  18. xtins
    xtins New Member
    26
    US
    I'll let you know tonight! Thank you.
  19. Mendel Leisk
    42,096
    Sadly, NOBODY does legal stops around here. (n)
  20. xtins
    xtins New Member
    26
    US
    Not working mate. You think my prius it's broken? 1488071428174.jpg 1488071432964.jpg 1488071435602.jpg
