Intelligent Power Module issue, as well as head gasket?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Saeval, Apr 20, 2021.
  1. Tim Jones
    Tim Jones Senior Member
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    Got a call Friday that the Parts were in and car to be done Monday. Same person that got it all wrong. I told her I doubt it.... and of course she calls back today and pump back ordered and do not know when they will have it.
    They have the master.
    #21 Tim Jones, Apr 26, 2021
  2. gromittoo
    gromittoo Active Member
    719
    288
    philadelphia
    2013 Prius v wagon
    If you search for the part number of the Prius V EGR Cooler, you will find that it was also used in one Lexus model. I assume Identical powertrain.
  3. Tim Jones
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    That why I post on here.... the v and hatchback have identical motors but the transmission is different. V has water cooled trani and different gears....
  4. Mendel Leisk
    42,323
    AFAK Prius v does have different gear ratios, but: the drain bolt for the inverter coolant circuit on the regular Prius is on the bottom of the transaxle.
    Tim Jones likes this.
  5. ChapmanF
    19,008
    I think the same transaxle casting is used for the liftback and the v, but the v adds a water jacket no. 3 cover over the passages colored lavender here, and adds a couple hoses to circulate the water there as well as in the green area. The liftback leaves off the water jacket no. 3 cover, so those passages are just exposed on the front of the transaxle and unused, and only the green area transfers transaxle heat to the coolant.
    Inside the case, it's the oil that circulates over everything and carries heat away to the aluminum casting, which is cooled both by passing air and by the coolant in the water passage(s).
    #25 ChapmanF, Aug 9, 2021
    Mendel Leisk and Tim Jones like this.
  6. machinemanX-S.A.
    machinemanX-S.A. Junior Member
    Daytona
    I wonder how things turned out? I had to replace my head gasket myself, but after much pre-igniting and misfiring. You certainly know when coolant is pooling in cylinder combustion chambers when stopped. Until you get misfiring, I would hope it is a slight leak in the coolant system hoses etc. The dealer leak-down tested mine and still found no signs of cause, so the only reliable evidence is the misfiring. Until then stick your fingers in your ears, and hope for the best. But please check your hoses. and check for white smoke in tailpipe. But that would only be when catastrophic. Going to hear crazy misfire before that.
  7. rjparker
    rjparker Tu Humilde Sirviente
    11,071
    6,937
    Texas Hill Country
    A borescope inspection can detect either the coolant (just drops if they keep it overnight and then pull the plugs) or a borescope can detect a steam cleaned cylinder.
    gromittoo likes this.
