interchangable batteries?
Discussion in 'Newbie Forum' started by rumblingsasquatch, Aug 23, 2019.
  1. rumblingsasquatch
    rumblingsasquatch New Member
    Biloxi
    can I put gen 2 battery cells in my Gen 3 2007 Prius?
  2. PriusCamper
    PriusCamper Senior Member
    13,470
    5,438
    Pacific Northwest, USA
    Yes, but the modules have to move on to the gen3 rack and you'd be downgrading in the lifespan of them if they are from a gen2 vehicle rather than purchased as replacement more recently...
    52,878
    welcome!
    hang on, 2007 is gen 2 (n)
  4. rumblingsasquatch
    Biloxi
    Actually, it's a Gen 3, I'm stupid! I was lost in thought on something else. Thanks though. I appreciate the timely response.
  5. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    As you own a gen 2 Prius I’m guessing your question is can I put Gen 3 battery’s in my gen 2?
    #5 Skibob, Aug 24, 2019
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    My brain just exploded....
    Gen 2 and 3 HV Battery modules are effectively identical to each other and are completely interchangeable.
  7. PriusCamper
    13,470
    5,438
    The modules are identical but the bus bar holders, voltage sensors, chassis, the rack and the end caps are different, even if only slightly, so you can swap the modules themselves, but everything else will need to be modified or swapped out.
    PriFi likes this.
  8. NotForTheBurnouts
    NotForTheBurnouts New Member
    Hi. Would you happen to know if Gen3 Prius cells are interchangeable in a 2014 Prius V?
