Interest in group buy for no-holes parking sensor
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AZGeek, May 15, 2012.
  1. AZGeek
    AZGeek Semi-informed Member
    627
    144
    63
    Arizona
    I am going to try to go onto Toyota's TIS site to get the bumper removal instructions for the 2010+ and then photo document the install and post. If I do that then you would just need to find someone in your area that is capable and willing. :)
    I actually thought about you and your "mod" when researching this sensor, figuring that I would be soon making the cracked spoiler mod myself. ;)
  2. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    I've heard back from Proxel regarding my question about needed the on-off switch for the front bumper/spoiler protection. Based on this, I'm definitely in on a group buy but want the DAM option. Start from the bottom and work up.
    you have just to specify for DAM protection and will supply the ECU
    with different software free of charge.
    Mauro
    Il 18/05/2012 14:11, Dark_matter_doesn't ha scritto:
    > Thanks for the response. How would I specify the system with the software modification in an order?
    > Dark_matter_doesn't
    > On May 18, 2012, at 2:42 AM, Mauro Del Signore<[email protected]> wrote:
    >> if you want to protect only the DAM (low spoiler) you could use the system always on when travelling but with a modification on our software on request.
    >> For the standard installation you must use the push-button switch.
    >> Regards
    >> Mauro
    >> Il 18/05/2012 04:11, Dark_matter_doesn't ha scritto:
    >>> I'm interested in your proximity sensor to protect the front bumper of my 2010 Prius, but I'm not thrilled about having to switch the system on and off. I'd like to leave it on all the time.
    >>> Is it possible/reasonable to just leave the sensor on all the time? Will false alarms become too annoying for a reasonable sensitivity level?
    >>> Thanks,
    >> Dr. Mauro Del Signore
    >> PROXEL SRL
    >> Via Val Della Torre 39
    >> 10149 Torino - ITALY
    >> www.proxel.com
    2 people like this.
  3. Dark_matter_doesn't
    691
    151
    Seattle, WA
    If all you're doing is install the Proxel antenna in the lower lip (as I will do), it shouldn't be necessary to remove the bumper cover. Removing the under-cover panel just behind the bumper cover on the bottom should provide adequate access.
  4. fangeva
    fangeva Junior Member
    43
    SF Bay Area
    Do we have enough members to start a group buy yet ???
  5. krazypriuslady
    232
    metro Wash DC
    Greeeaatt :p
    You should make a trip here. (after you perfect the install on yours ) :eek:
    I have the epoxy stuff to put on the spoiler. It's just my inertia now..
  6. AZGeek
    627
    144
    63
    Arizona
    We need one more to confirm they want one. Then we will have the minimum 4 needed to get the discount.
    new iPad ?
  7. bzyrice
    bzyrice Active Member
    805
    324
    West Palm
    I can confirm to be the 4th member. And I can install this myself. Shouldn't be too hard. I can also make a DIY. I have made a few in my time :)
    I would want the ECU change for always On that Dark Matter was able to get confirmation on.
    Paypal Ready! Just let me know what I need to do!
  8. madman
    madman Junior Member
    46
    23
    Los Angeles
    I'm curious about the dual sensors. Is there a different tone or beep depending on which part (bumper or spoiler) is getting close to contact? In theory, I guess the dual strips of the sensors are just covering more area, meaning the beeping sounds when any objects are nearing contact. If that's the case, isn't only one sensor required if optimally placed at the right position on the bumper? I'm confused. Maybe someone can explain or I'll email Mauro for clarification.
  9. Jwb2781
    Jwb2781 Junior Member
    45
    Seattle, WA
    And I will confirm. I want the front. With my lowered car it would be nice not to hit the curb. always on sounds good too.
  10. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Post a running list of those interested/confirmed to make this GB happen (follow this example).
  11. bzyrice
    805
    324
    West Palm
    Ok.. I'll start the list since I've always wanted a solution like this but could never find it at the time.
    Name / Screenname / Want always on ECU?
    01. RJ - bzyrice - yes
    02.
    03.
    04.
    05.
  12. GoldPianoGarden
    GoldPianoGarden Bling Meister
    841
    74
    98
    Brunswick, GA
    Unless someone knows of a better model/solution available, count me in....yes, always on...
  13. AZGeek
    627
    144
    63
    Arizona
    Thanks to RJ for getting the list started. I added choices for front, rear, or both. We definitely have enough confirmed interest for a group buy. :) There are a few others who have indicated they want to purchase.
    Please review the list, make changes as needed. I will contact Mauro on the 25th to get specifics on the the order for the group buy.
    Name / Screenname / Want always on ECU? / Front / Rear / both
    01. RJ - bzyrice - yes - front?
    02. Sam - AZgeek - yes - front
    03. GoldPiano - yes - front?
    04. Jwb2781 - yes - front
    05. Dark_matter - yes - front
    Those expressing interest but no confirmation:
    06. fangeva
    07. tracksyde
    08. krazypriuslady
  14. bzyrice
    805
    324
    West Palm
    Yes just front for me.. I have backup camera.. No need for rear.
  15. Dark_matter_doesn't
    691
    151
    Seattle, WA
    [cold viruses have consumed my brain]
  16. Jwb2781
    45
    Seattle, WA
    Read above...I would like front and maybe rear..total cost with Display? Including shipping.
  17. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    I have to admit you have piqued my interest in this system. There were a number of units discussed, to I want to be clear on which unit we are purchasing.
    If this unit will display the distance and hash marks over the backup camera video in the MFD display of a '08 Gen II JBL/NAV Level 5 Prius, I WANT ONE!
    If this is not that unit, not so much, but, please point out which unit we are considering, I will revisit it, and might reconsider!
    Thanks for your efforts! :D
  18. krazypriuslady
    232
    metro Wash DC
    Can't commit w/o install ideas
    Good luck. Will be reading with interest!
  19. Dark_matter_doesn't
    691
    151
    Seattle, WA
    Let's get the first batch on order!
  20. fangeva
    43
    SF Bay Area
    Please confirm me for one set of sensor, just want the set for rear bumper....
    Thanks !!!:)
