Interesting article on "deadly" keyless ignition
Discussion in 'Gen 3 Prius Main Forum' started by Oskar, Aug 27, 2015.
  1. JTM2955
    JTM2955 Active Member
    475
    185
    Do you know why sharks don't eat lawyers? Professional Courtesy...
    LG G3 T-MOBILE phone ☎
  2. ETC(SS)
    7,554
    Be careful about depending on that. ;)
    We've had a few technicians (not me) lock themselves out of cars because the battery in the fob was worn and got shifted to another part of the car before the 'lock and leave.'
    fuzzy1 likes this.
  3. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    Good advice. I'm not that trusting of technology, or my memory.
  4. ETC(SS)
    7,554
    Most of the time you'll get a "battery low" warning when you shut down the car with a low fob, but we've had some peeps get gear out of the cargo bay and accidentally leave the fob there....only to do a lock-n-leave.
    Reason #2653 to tie-wrap a keylet to an exterior hard point and hide a (debatteried) fob inside the car.
    Good Luck!
  5. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    Some years ago, the "Hemlock Society" said that connecting a hose to your tailpipe and breathing is no longer a reliable means of passing away. The reason is the catalytic converter. Nonetheless, the cars do emit some carbon monoxide which I imagine can build up in the garage and then invade living space. I personally find the piercing alarm a good reminder to turn off the car -- sometimes I forget because the car is so quiet when it is parked -- but perhaps this isn't adequate for others.
  6. CR94
    CR94 Senior Member
    2,829
    1,242
    Northwestern S.C.
    Catalytic converters are not very effective until they've had time to warm up after a cold start.
    JTM2955 likes this.
  7. qdllc
    qdllc Senior Member
    1,377
    400
    CO2 will still kill you. Just not as quickly. Watch Apollo 13. :cool:
    JTM2955 likes this.
  8. Jhutbeer
    Jhutbeer Junior Member
    Vancouver, Canada
    It would not be a bad thing to install a CO detector in your garage as well as having the Prius beep a few more times when you step out of it and close the door.
