Interesting Article
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by RBooker, Apr 11, 2013.
  1. RBooker
    RBooker Member
    154
    56
  2. Ken Blake
    Ken Blake Active Member
    351
    180
    Portland, Oregon
    Unless Canada is getting a different version of the Plug-In than the U.S., some of their figures for the PiP were inaccurate. Also, some members on this forum have reported being able to sustain full electric operation in the same temperatures, so clearly the author of the article was not conversant with how to avoid activating the ICE.
  3. 3PriusMike
    3,101
    2,419
    Silicon Valley
    It is amazing how an author can write something so definitive...and mention it over and over and it is just wrong. Unless there is something different about the Canadian version or it was very cold where he is.
    Mike
  4. Ken Blake
    351
    180
    Portland, Oregon
    He mentioned 3C as the temperature at one point...That's 37.4F. I've operated my PiPa in full EV without a problem at that temperature. Also, he stated that it would kick on the ICE at speeds above 80 kilometers per hour. That should have been more like 100 kilometers per hour.
  5. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Maybe they used Power Mode?
    I have no problems keeping it in EV mode in temps 32F and above.
  6. bisco
    52,501
    articles like this make me wonder why i believe anything i read.:mad:
    3PriusMike likes this.
  7. bisco
    52,501
    my pip has never 'fired up on a cold morning to preheat the hvac and cat':confused:
  8. Drake
    Drake Junior Member
    71
    16
    Quebec, Canada
    2013 Prius Plug-in
    My Canadian PiP do NOT start at 3C. It will start below -10C but certainly not above freezing temperatures.
    I think the Canadian PiP is exactly the same as the US. (Except we do not have HUD display and/or Entune access :()
  9. RBooker
    RBooker Member
    154
    56
    In upstate NY my experience was similar. At home I park my PIP in an unheated garage. In the mornings ICE would start when temperatures were in the upper 30s. As the temperature dropped the frequency of ICE engagement increased. At work I park in a heated garage (~50 degrees). Even when the temperatures was in the 25 to 27 range I could make the return trip home in EV.
    Initially, I was certain the unwanted ICE startups would kill my overall fuel effciency. It turns out my fuel efficiency (gas only) actually increased from 114.4 mpg (11/10/2012) to 124.7 (2/9/2013).
    babybird likes this.
  10. 3PriusMike
    3,101
    2,419
    Silicon Valley
    Certainly unwanted ICE startups can reduce your mpg. But the fact is that when you plug in you are getting extra energy from teh battery compared to getting it from gas. If you are using gas and electric if you go far enough to use all the battery capacity you will be getting a benefit because the HV mode times that the ICE stays off will be more frequent and longer...or your gas usage at >62 mph will be less.
    On very long trips the addition of the 3 kw-hrs of battery power will be negligible...but then the Prius gets higher gas-only mpg than any other plugin.
    Mike
