Interesting battery info I found.
Discussion in 'Gen 2 Prius Main Forum' started by Prius92, Aug 7, 2022.
  1. Prius92
    Prius92 Active Member
    595
    122
    Iowa
    NiMH battery technology, how to charge Nickel Metal Hydride
    Batteries tutorial for design engineers, as well as NiMH chargers.
    This is rather interesting, but not sure how accurate. This means a 6.5Ah module would be charged to 10.8Ah?
    Also since the car itself doesn't use all of the capacity, wouldn't that be rather moot?
    My hobby chargers never see this delta V bump, so I always charge at 500MAh, which is slightly less than C/10, but a nice, safe charge. I terminate at 7200MAh. But some people do as much as 9500MAh, which seems a bit silly as I don't think you can push more capacity into the battery than it has to begin with.
    According to this site, a NiMH battery is fully charged at 1.4V per cell, so on a Prius module, this would be 8.4 volts, usually my modules are at 8.4-8.5V a couple hours after they are done charging.
    I think going over 7200MAh is a waste, but if others want to say why or why not, I'm all ears.
