Interesting Reddit Discussion from r/Prius
Discussion in 'Gen 5 Prius Main Forum' started by Paul Gregory, Sep 19, 2024.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,338
    614
    Alberta
    2024 Prius Prime
    XSE
    So, for the record, you are still maintaining that engine braking happens automatically, despite you providing no evidence?
    I have provided much evidence, all of which was ignored, for the cause of trolling.
  2. Trollbait
    12,814
    What evidence?
    fuzzy1 likes this.
  3. fuzzy1
    10,690
    Note to new readers: Paul rejected even Owner's Manual pages posted by another reader as "evidence". It isn't clear that he will accept any evidence short of a ride-along with someone else demonstrating certain actions.
    ... or possibly even then, considering that the new Primes are quieter and more seamless than the old Gen3s, quiet enough that many people his age, with typical hearing loss for such age, may simply be unable to hear it. If that is combined with refusal to believe add-on aftermarket tachometers, then there may be no possible 'evidence' that he would believe.
    The "evidence" Paul provided, clearly avoided the test conditions that various members requested, instead staying with other conditions that he was pre-warned would likely not initiate the engine braking being discussed.
    Didn't he also indicate that he had another and better test opportunity was coming up? Did I miss any "evidence" posted from that?
    #23 fuzzy1, Sep 22, 2024
    Gorgonzola, Blackat and Fred_H like this.
  4. KMO
    KMO Senior Member
    2,028
    751
    Finland
    2023 Prius Prime
    And yet neither Paul nor anyone else has ever observed such behaviour.
    Unshakable conviction that the car does something dangerous he hasn't ever seen it do, and utter incredulity that it does something safe many have reported having seen it do.
    Probably a good idea to report it to the vehicle safety people, just in case. A nice long report. Take your time...
  5. Gokhan
    Gokhan Senior Member
    6,708
    2,658
    Paramount CA
    As far as I understand, the B mode does not do anything other than to change the brake-pedal modulation. In other words, in the B mode, you need to press the brake pedal less to obtain a given rate of regenerative braking. The B mode does not boost, increase, or alter the available regenerative-braking power. The boost settings of the B mode described in the owner's manual only modify the brake-pedal modulation, not the available regenerative-braking power. All the B mode does is to decrease the needed brake-pedal travel for a given rate of regenerative braking for driver's convenience during downhill driving. There is no difference in the B mode than in the D mode otherwise—including the maximum regenerative-braking power that is available. You are not going to have more regenerative braking in the B mode than in the D mode—you will only have to press the brake pedal less. The B mode is also not recommended for better fuel economy in most driving conditions, as it makes it harder to drive smoothly. Therefore, you are better off using the D mode than the B mode in most scenarios.
    Thanks to other posters, I get it that you can also have engine braking without combustion through the pumping losses in the engine, which could be useful in downhill driving if the traction battery is full or the maximum available regenerative-braking power is exceeded.
    #25 Gokhan, Sep 22, 2024
  6. hill
    9,018
    LOL
    at first blush - post #5 seemed to be somewhat "over-the-top" & uncalled for.
    but not anymore .
    soft_r likes this.
  7. Paul Gregory
    2,338
    614
    Alberta
    2024 Prius Prime
    XSE
    What you posted was a false assertion. Mode B is not for "Regeneration Boost." It never was.
    I have posted much evidence to that effect, all of which was ignored.
    To a troll, facts are the enemy.
  8. bisco
    52,804
    no point arguing with a flat earther
    Gokhan likes this.
  9. soft_r
    soft_r Active Member
    198
    167
    Beverly Hills
    2024 Prius
    It's honestly amazing how people get sucked into this topic and how often it keeps getting rehashed. It's like a magnet for idiots.
    hill likes this.
  10. fuzzy1
    10,690
    Q.E.D. As another posted copied from the Prime's Owner's Manual (follow link from post #23 above):
    This is specific to the Primes, but Paul's profile shows that he does have a Prime.
    #30 fuzzy1, Sep 22, 2024
  11. Gokhan
    6,708
    2,658
    Paramount CA
    I don't know what the intense fight in this thread is about because I didn't read the previous B-mode thread. However, I am not sure if anyone who has posted in this thread, including the OP and responders, understands what the B mode and boost setting do, as there hasn't been any coherent post.
    Translation of the owner's manual: The B mode and the boost setting do not do anything other than changing how the accelerator- and brake-pedal angles control the amount of regenerative braking. You can still operate the car identically in the D mode as it would operate in the B mode as long as you operate the two pedals properly, and the maximum available regenerative-braking power is the same regardless of the mode (D or B) or boost setting.
    So, don't expect to use less friction braking in the B mode vs. in the D mode regardless of your boost setting—you won't.
    This is in contrast to a conventional automatic transmission, where the L and 2 gears apply brake bands in the transmission to increase the drag on the car through friction.
  12. Gokhan
    6,708
    2,658
    Paramount CA
    Here are some better questions:
    • Is the maximum available regenerative-braking power the same in Gen 4 vs. Gen 5?
    • Is the maximum available regenerative-braking power the same in the Prius HEV vs. the Prius Prime PHEV?
    • Does the B mode and/or boost setting, the latter of which is only available in Gen 5 Prius Prime PHEV, change the maximum available regenerative-braking power or do not change it but only modify the accelerator/brake-pedal operation as I claimed above?
    These questions could in principle be answered through experiment. There are physics kinematics apps for smartphones, which use GPS to measure the speed and acceleration. You can drive to a certain speed like 60 mph on an empty flat road and then use the maximum available regenerative-braking power according to the drive monitor on the display to see what the deceleration corresponding to the maximum available regenerative-braking power shown on the drive monitor in the display is in different modes, settings, and the HEV and PHEV models.
    I doubt Gen 4 Prius Prime PHEV is capable of more regenerative braking power than Gen 4 Prius HEV, despite the much larger battery that would allow a much larger regenerative-braking power due to a much larger current. Is this the case for Gen 5 Prius HEV and Prius Prime PHEV as well? And do the B mode and higher boost settings in Gen 5 Prius Prime add any more to the maximum available regenerative-braking power or do not as I claimed?
    And, from the owner's manual, it is clear that internal-combustion-engine braking without combustion taking place—that is using pumping losses without spark/fuel—only operates in the B mode, which makes sense because, otherwise, it would make the fuel economy worse in the D mode.
    #32 Gokhan, Sep 22, 2024
  13. Hammersmith
    Hammersmith Senior Member
    2,462
    2,523
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The "debate" all comes down to one thing:
    Paul believes engine braking ONLY occurs when the gear selector is in B.
    Everyone else says engine braking CAN occur in D when certain conditions are met(HV battery is at or near true max charge and braking is being applied by the driver, and also maybe when HV is full and cruise control is trying to maintain a speed while going down a steep grade).
    That's pretty much it. I think we're up to four threads and hundreds of posts on the topic.
    <wherestheheadbangingemojiwhenyouneedit>
    Fred_H, fuzzy1, Gokhan and 1 other person like this.
  14. soft_r
    198
    167
    Beverly Hills
    2024 Prius
  15. bisco
    52,804
    res componitur
  16. Gokhan
    6,708
    2,658
    Paramount CA
    And that should have been pretty obvious to anyone.
    Perhaps he didn't realize that you didn't need combustion for internal-combustion-engine braking, as it happens through the pumping losses, which don't require combustion.
  17. Hammersmith
    2,462
    2,523
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    No, I'm pretty sure he understands what engine braking on the Prius is. What he believes is that the car's programming only allows it while in B mode.
    Gokhan likes this.
  18. KH111
    KH111 Member
    89
    45
    Travelers Rest, SC
    2024 Prius Prime
    XSE
    Hopefully I'm not beating a dead horse here but when I shift to "B" mode on a steep downhill near my house the regenerative braking definitely increases WITHOUT touching the brake pedal. You see it on the display as well. If I don't use "B" mode on the hill I have to use the brake pedal to increase the regen braking (still not using friction braking) to avoid exceeding the speed limit, in "B" mode I don't have to touch the brake pedal. I agree "B" mode changes the modulation of the pedals giving the car more of a Chevy Bolt One Pedal Driving feel.
    KH
    Gokhan likes this.
  19. Trollbait
    12,814
    Cause you're in a Prime. The hybrid doesn't have that huge battery. So B increases the engine braking. That will also happen in a Prime when the battery is fully charged.
    hill likes this.
  20. Paul Gregory
    2,338
    614
    Alberta
    2024 Prius Prime
    XSE
    When your battery can take it, of course you will feel some regenerative braking, when you let off the accelerator (and even when you apply 'B' I suppose). But if your battery is at full charge, there is absolutely nowhere for that regenerative charge to go. The Prius engineers foresaw this, and designed in an engine brake (B). It's nothing elaborate; it just manipulates the valves to compress air. The excess energy is dissipated as heat.
    You may take engine braking for granted, because it's inherent in a conventional car, but it does not exist at all when a Prius is coasting downhill with a full battery. Scenario: you are coasting down a long slope, your gas engine is not running of course, therefore it's not providing any engine braking (once the hybrid battery is full). So the Prius has no rolling friction at all, going down the hill. This may not seem like a big deal, but it's akin to shifting a regular car into neutral. It will continue to pick up speed until it becomes a dangerous situation. You can use your brakes, but they soon overheat and burn out.
    A fair point might be that engine braking should be automatic, not manually activated with the 'B' shifter. Maybe in later generations. But then everyone will be really convinced that "B" is some sort of "super regeneration."
    I have posted plenty of links on here explaining how this works.
    #40 Paul Gregory, Dec 23, 2024
