Interesting things you learned about the Prius long after buying it
Discussion in 'Gen 3 Prius Main Forum' started by Johnny Cakes, Dec 5, 2019.
  1. RRxing
    RRxing Senior Member
    2,546
    1,822
    NEPA
    At least it's visible on the Gen IV. I have no issues with it.
  2. kc5dlo
    kc5dlo Active Member
    266
    163
    DFW TX
    2021 Prius
    Found a button under the dash that resets the current tire pressure setting. Had a phantom tire pressure warning light that would blink, turn on and off at random times despite all tires being at the desired pressure. Press and hold the button till the dash light stops blinking and no more phantom warnings. Many times that light would come on in an unfamiliar area out of town or in bad weather and would cause some nervousness till I could verify all was actually fine.
    Another item helpful for me was the hiding spot for the cargo cover. Much better than in the garage LOL.
    Otium, grantb3 and Johnny Cakes like this.
  3. Siward
    Siward Active Member
    314
    128
    Toronto
    I learned some interesting (also not nice) things of hybrid ownership:
    1) If you run out of gas, you need to fill at least a quarter tank to "maybe" startup. Or you may end up at the shop for a reset.
    2) You can't to shift to neutral for towing without turning on the car. Makes things complicated if the car is completely dead.
    3) If your 12V battery dies, you either need to boost just to get to your battery or you need to crawl to the hatch release. Gen4 fixes this.
    4) If your 12V battery is low, it is hard to predict how the Prius behaves. 12V boots up computer which ramps up 120V which starts car.
    None of the above has happened to me, but what the hell?
  4. ChapmanF
    18,182
    Try turning the steering wheel while the car is parked. You'll notice you can; the car does not have a steering column lock for theft prevention as older cars did. The only-computer-unlocked transmission is what takes over the theft-prevention duties. (Note: this is Gen 2 and later; Gen 1 did have a steering lock, and a regular mechanical park linkage from the shift lever.)
    But you can boost using just the boost terminals provided under the hood, at which point you might elect to just start the car, drive to a happier place, and then get to the battery if it needs to be replaced and not just recharged.
    That '120' should be closer to 200, the rough voltage of the large traction battery, which is disconnected when the car is off. The 12 volt battery does need to have enough power to pull in the relays that connect the traction battery; at that point the larger battery takes over.
    The "low 12 volt battery" ⇒ "hard to predict how the Prius behaves" is a notion that has a lot of adherents on PriusChat, but not all of us. In all of my experience, a Prius is quite predictable:
    • If the 12 volt battery is in a good state of charge, the car will start, and work fine
    • If it's pretty close to dead, lights and dash displays might dim out while attempting to start, and it might start, or not, maybe with a little help from you, like pulling the brake pump relays. If it starts, everything will pop back to full brightness and be fine. If the voltage dropped at some point below 8.5 to 9, some of the computers will have logged trouble codes that say so, which are, of course, correct.
    • If it's closer to dead than that, it won't start, so you'll need to jump it, and probably reset the clock, radio presets, and auto window motors.
    There is a widespread alternate view on PriusChat that can be roughly translated as "absolutely anything unexplained happening in a Prius is probably the 12 volt battery because computers, you know", it just doesn't have support in the world of experience I live in, anyway. Often it strikes me as more of an easier substitute for the legwork to find out why the Prius is doing the unexplained thing. The computers in the "because computers, you know" are built with onboard regulators that are stable down to input voltages way lower than where the car just isn't going to start.
    Mr. F, Bay Stater, AzWxGuy and 3 others like this.
  5. fuzzy1
    10,447
    A number of PC members have found that the shop visit is not necessary. Just disconnect the 12V for long enough to clear the computer memories of this saved data flag.
    (The other part, about adding at least several gallons, is disclosed in the Owner's Manual.)
    Bay Stater and Mendel Leisk like this.
  6. Mendel Leisk
    41,440
    I found this, and it appears to be the only reference, on page 37 (printed page number), of a pdf of the 2010 Owner's Manual (North American):
    I wonder if "make the low fuel level warning light go out" is synonymous with "is sufficient for the engine to start"? They sure don't spell it out.
    ASRDogman and Tideland Prius like this.
  7. burebista
    burebista Active Member
    187
    129
    Romania
    OMG! I just... OMG! :eek:
    Now I just slowly crawl back under my rock...
  8. kc5dlo
    266
    163
    DFW TX
    2021 Prius
    I have noticed when getting gas and the the last pip is blinking, the point at which the gas gauge stops blinking, the gauge goes to 2 bars and the pump is at about 2 gallons.
  9. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    This is also the amount of gas required at fill up to reset the DTE value. I’ve gotten away with 1.3 us gal during summers though.
  10. Tideland Prius
    16,556
    Probably the Jetta. The Gen 3's top glovebox is pretty bare. (The Gen 2 had a shelf and rubber inserts. I added a thin foam insert to my Gen 3 gloveboxes and cupholders to reduce scratches and noise)
    I prefer the Gen 3's "pull down" handles than the Gen 4/Prime's "push" down. Less stress on my wrists :(
    mrwhsprs likes this.
  11. grantb3
    grantb3 Junior Member
    60
    Orange County, CA
    There's an extra "click" on the dash brightness dial that lets you get full dash brightness with the headlights on.
    You need to lightly separate the base wings on the rear wiper so that the rear wiper is fully freed (to clean the rear window for instance).
    Mr. F, Threej, mrwhsprs and 2 others like this.
  12. Johnny Cakes
    Johnny Cakes Senior Member
    1,046
    780
    Virginia, USA
    Great tip! Then the rear wiper can be brought out of the way just like the front wiper for window cleaning at the gas station.
    Raytheeagle likes this.
  13. Johnny Cakes
    1,046
    780
    Virginia, USA
    While a "Jump-n-Carry" (portable jump battery) is a great idea, do NOT store it in the "trunk" space under the floor/above the tire.
    When the battery dies, the electric latch for the rear hatch dies also. While you can rip up the floor from inside the car to get into that space (and then access the manual release for the hatch), it is a huge hassle.
    Please do not ask me how I know this.
  14. Mendel Leisk
    41,440
    There is a manual hatch release. Not a lot of fun to access I hear. Still, under the hatch floor in the tray is such a perfect fit for the JNC, it's hard to resist.
    Johnny Cakes likes this.
  15. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    So no explanation why not to store the JNC under trunk space. How will that convince me not to do that?
  16. Mendel Leisk
    41,440
    Presumably if it's your Prius with the dead battery, and the electric hatch release isn't working? That was my take.
  17. Johnny Cakes
    1,046
    780
    Virginia, USA
    Insert the word "because" between the first and second paragraphs of the post. :)
  18. spudnut
    spudnut Active Member
    145
    159
    Idaho Falls/Pocatello, ID
    Backing down a 1/4 mile steep road, I found out it doesn't regen in reverse!
    Johnny Cakes and douglasjre like this.
  19. douglasjre
    douglasjre Senior Member
    2,180
    718
    Null, NL
    Riding the brake pedal gently under 10mph prevents charging the pack
  20. douglasjre
    2,180
    718
    Null, NL
    The ecu is programmed not to rev up a cold engine. In hot climate full ac in conjunction w start n drive off behavior deep cycles the pack shortening its life
