Interference stopping my remote locking working
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mathewjg, Oct 17, 2021.
  1. mathewjg
    mathewjg Member
    84
    49
    For the last two days I have been unable to use the remote control to lock or unlock my 2nd Gen Prius when its parked on my drive. When I go somewhere else the problem disappears. I have read that having a low charge on the 12v battery can cause this but even after returning home from a 50 minute drive I cannot lock or unlock the car remotely, but after a short drive up the road to a different location, everything is fine. The problem occurs any time of the day - which makes me suspect the cause cannot be florescent lighting (not that I have any - but perhaps my neighbours).
    My house is full of gadgets but nothing that has been installed or switched on recently. My plan is to turn off the main house fuse and see if that clears the problem. But any other suggestions.
    Ideally some kind of RF frequency/spectrum analyser would be useful specially if it could identify the direction that the assumed interference is coming from.
    I doubt there is any near my house but has anyone had problems with 5g causing this?
  2. Leadfoot J. McCoalroller
    8,175
    7,680
    Pennsylvania
    2018 Prius c
    A battery powered AM radio is an excellent cheap RF detector that can help you find many problems. The typical internal ferrite bar antenna is very directional, which really helps you locate the offending noise source fast.
    Of course there are lots of fancier gadgets which draw a graphical spectrum for visual analysis, but they tend to cost more.
    Dimmable LEDs are a very common culprit these days. Many car owners have found that changing the interior lights to LEDs will cause the remote locks to be inoperative for a few moments while the car is actively dimming down the lights, which is coincidentally when some drivers are walking away and trying to click the lock button.
    If you have some LEDs being driven by a dimmer in or on your house, they would be among the first things to check.
  3. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    And you are not having your battery and it's connections tested.......why exactly ?
    Could be door actuators failing too......with a "coincidence" factor thrown in.
  5. dolj
    dolj Senior Member
    8,606
    4,368
    Wellington, New Zealand
    I had exactly this and verified it was only a problem on my driveway. As soon as I moved 5 m or more away the lock/unlock returned to working perfectly.
    I check all usual suspects and checked the fob and 12 V battery voltages (and 12 V connections) and found no problem there. I don't have any frequency analyser equipment so couldn't check that.
    After a few days, without doing anything else, it started to lock again on my drive and hasn't happened since.
    I concluded it must have been something transmitting a radio frequency that interfered with the door lock frequency. 5G wasn't even a thing then, but I did wonder if it might be a 4G tower. Looking back I discounted that as a cause due to the relatively few days it happened.
    Also of note, it only happened to a non-SKS Prius. The SKS Prius had no issues during this time.
    For me it was just one of those mysteries of life.
    #5 dolj, Oct 17, 2021
  6. mathewjg
    mathewjg Member
    84
    49
    Many thanks for the replies. It has cleared itself. I am sure this is a complete co-incidence but it seemed to stop working exactly after a flypast of four USAF fighters rehearsing for the NFL match at Tottenham Hotspur ground on Friday and started working after another flypast today when they were heading for the match!
  7. fuzzy1
    10,603
    A military connection would be no surprise to me. Near here, decades ago, many people (including a coworker) living close to Naval Station Everett experienced failure of garage door openers and other radio devices for a couple weeks, while certain big ships were in port. The issue did appear in some local news, along with a statement that it was related to naval operations. The RF emissions from certain equipment caused interference, and it was not expected to clear until those ships left.
  8. sam spade 2
    7,035
    2,804
    2017 Prius c
    And sometimes that is done on purpose.
    I found that my Garmin GPS became erratic and totally inaccurate every time I came close to Regan National airport in DC.
    I suspect that happens close to other major military bases too.
    :eek:
  9. fuzzy1
    10,603
    With this military stuff, it would definitely be on purpose. They have priority use, other users of the same bands have no choice but to accept the interference.
  10. sam spade 2
    7,035
    2,804
    2017 Prius c
    That's not quite what I meant.
    The "civilian" GPS system is good enough to be used to "target" a military strike on the cheap, if you are a terrorist for example.
    The system that the military actually uses likely is NOT "on the same bands".
    The civilian system is intentionally scrambled to prevent it's use to direct a strike against a military base......or the airport that the President uses.
  11. fuzzy1
    10,603
    I was referring to interference in the band that resulted in OP's loss of remote car locking, and an Everett neighborhood's loss of remote garage door opening. At least in the later case, the military was deliberately using that band for other purposes. It is not a GPS band.
    Military GPS is a multiband system, civilian GPS is a subset of that. The non-civilian side is always 'scrambled' to keep them off, the civilian-accessible side is adjustable to limit accuracy, and *.gov has additional tools to further degrade or block it in zones of interest (e.g. battlefields) as needed. *.gov also has websites announcing when and where larger scale tests will be interfering with GPS on large scales of interest to aviators.
  12. mathewjg
    mathewjg Member
    84
    49
    Amazing info. Many thanks everyone
