Interior Fuse Box
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by James Cooper, Jan 14, 2022.
  1. James Cooper
    James Cooper Junior Member
    Las Vegas, NV
    Today I blew the fuse for the No. 1 power outlet while using a Viair tire inflator. I found the two fuse boxes under the hood but I cannot find the fuse box inside the car. The manual kind of shows were the box is via a drawing but I see no fuse box and I have firmly pulled on every part of the area indicated in the manual but I cannot find the fuse box.
    Can someone post a photograph of where the fuse box is located inside the vehicle? It would be a big help to me.
  2. pghyndman
    pghyndman Active Member
    498
    465
    CT shoreline
    Here ya' go:
    Raytheeagle and Salamander_King like this.
  3. Salamander_King
    Salamander_King Senior Member
    10,970
    8,853
    New England
    It is very hard to see it under the dash. It's located further to the front and left of the car from the OBDII plug. You really have to be laying on the floor with your head facing up to see it. Here is the photo. The green thing is the OBD adaptor in the OBDII plug. The photo is looking up to the underside of the dash taken with selfy mode if that helps to orient the location.
    pghyndman and Elektroingenieur like this.
  4. Salamander_King
    10,970
    8,853
    New England
    BTW, the Viair inflator is really good. I have one but even the smallest portable one 70P which I own has the spec of Max. Amp/Watt Draw: 15A/180W. PP and almost all of the passenger cars I have seen have the 12v outlet with a 10A fuse which is too small for the max draw of the Viair inflator. If you need to use it off of the car's 12v battery, you will have to use a direct connection to the 12v battery posts using the alligator clip extension cord like this. Yep, I have blown the fuse on my car using my Viair 70P before.
    Raytheeagle and pghyndman like this.
  5. James Cooper
    Las Vegas, NV
    Thank you, I'm sure that I can find it now with your help. Thank you for taking the time to snap a photo!
    Salamander_King likes this.
  6. James Cooper
    Las Vegas, NV
    Thank you for taking the time to reply to my query but from the diagram in the owner's manual I still couldn't find it.
  7. James Cooper
    Las Vegas, NV
    View attachment 221464 [/QUOTE]
    Thank you. Great idea. I'm on Amazon right now buying one. Thanks for the suggestion.
