Interior LED Install Question
Discussion in 'Gen 3 Prius Accessories and Modifications' started by kmkremer, Mar 18, 2013.
  1. kmkremer
    kmkremer Member
    227
    30
    San Diego
    For those of you who have replaced the interior lights with LED's, what is the secret to removing the cover over the dome light in the rear roof area? I did a search and saw some comments about seperating the clear cover from the surrounding plastic trim. There are 2 indents on the front edge between the lens and the trim but I can't get it to budge. I'm afraid I'm going to crack the cover. Any help would be appreciated.
  2. Austin5
    Austin5 Go Bruins
    34
    Boston MA
    flat head screwdriver, pry at the two indents, it will come, have done it twice, no breaks.
    Careful. The bulb will be hot if its been on.. For some reason seemed WAY hotter than the front ones.
  3. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    I use a Xcelite "Greenie" Model R3322,
    OK it's the engineer in me, any small blade that will not snap will do, slowly work the tab on the lens housing until it pops out. It just takes patience!
    Monkey Wrenches should not be required at any point!
  4. kmkremer
    kmkremer Member
    227
    30
    San Diego
    That's good to hear. My knuckles are scraped, my ego is bruised and my patience is gone for the night. I'll make another run at it tomorrow.
