Interior LED Lighting?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by FreakinToddles, Aug 30, 2009.
  1. Tideland Prius
    16,678
    So that's a good thing in terms of using it as a maplight because you get a focused beam of light. But the problem is that maplights double as a personal light (i.e. they're also used to flood the front area with light). Would be nice if it was separated like the Gen 2
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Yeah, that's why I'd like to see pics if he can post some up of how they light up the car having such downward focused beams in the map lights. Since I put those blue visions in the map lights I can tell they are brighter while simply sitting in the drivers seat. I'd almost think those LED's may be a bit too powerful if not spread out a little bit more...
  3. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    I'm kinda stuck on two lights:
    Dome light - how is it removed - I pry it, but it doesn't want to budge, and I don't want to break it...
    Map lights - I can pull the plastic from the overhead off (in front near window) - but what then?
    TIA!
  4. hotbrass
    hotbrass New Member
    312
    35
    Cowtown
    Get a plastic pry bar set from an auto store or Harbor Freight is where I got mine for $5.99.
    It is much easier when you locate the plastic fasteners and pry at that point. But it is easy to do with your hands also. Just be sure to only supply enough force to pop the fasteners loose and not bend the housing which will crack the lens, and start at the front/glass side and work back.
    I had no problem the first time getting mine off. In fact the fasteners came loose from the cover instead of the socket. Not sure how, but I didnt break anything. I use a plastic pry bar now and it is easier.
  5. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Go to post # 69 in this thread. I showed how I removed the map light lenses with pictures even.
    Post above that I showed how to get to the bulb in the doors.
    I have not done the rear dome light yet so cannot comment on it.
  6. Tideland Prius
    16,678
    Use a flatblade screwdriver. Be careful not to damage the plastic (not the clear stuff but the solid colour plastic around the cover). They're quite soft.
    Just look for the "slots" where you can slip your flatblade in and pry it out. They're very very easy to remove. For the rear dome lamp, look for the side that has two of those slots.
  7. rrolff
    1,610
    246
    So Cal
    Thanks to all - I was able to get the dome off, and when I put the cover on, the switch is broken (???) :mad: It's never as easy as it should be...
  8. Tideland Prius
    16,678
    huh? how did the switch break?
  9. jsharpe
    jsharpe Member
    111
    26
    Last night I swapped out the Philips BlueVision 5w5 bulbes I had in the license plate and parking locations. For the Parking lights I tried both the 5 led and 9 led versions from superbrightleds and to my surprise the 5 led version was significanlty brighter. Although to my eye both appeared to be the same color, the 9 led version is spec'd at a higher color temp. Both look a bit blue compared to the LED low beams which I think looks better than the BlueVision bulbs which, although whiter than stock were still more yellow than the LED low beams.
    For the parking lights I tried these off eBay:
    The above lights work very well and are a very nice cool white (more white than the BlueVision, but not blue. They are a *very* tight fit though. I actually ended up filing them down a bit just to get them installed.
    I'm still waiting on an order for some blue SMD led's for the doors to match the illuminated sill plates. And for the interior map/convenience lights I think I'll build up something based on the new CREE XPG. It's a single SMD puts out around 370 lumens depending on how it's driven and has a nice wide illumination angle which I think would be a great match for most of the remaining interior lights.[​IMG]
  10. robinson
    robinson Junior Member
    31
    DC
    Man, this place is AWESOME! Thanks for the read (long, but good...)
    I can't wait to redo my interior lights. I have ordered the exterior ones, so hopefully that won't take too long.
  11. HI MPG
    HI MPG Active Member
    789
    133
    93
    Orange County, CA
    Was curious if anyone can tell me what type of LED bulb this is in the attached pictures? I pulled this bulb from the glove box, and these are the same type of bulbs for the footwell lighting in the Prius IV and V. I was looking to change them out to white LEDs to match the rest of the white LEDs I used for the interior. They are currently an amber-ish orange. I am hoping there is someone out there who would know...
    The only identifiable markings on the housing are PBT B4 on the back of the unit and FG34A on the top. The bottom of the unit has two prongs on the inside for the plug from wire (for a lack of a better term)
    Thanks in advance for your help.
  12. Tideland Prius
    16,678
    I thought those were SMDs. Maybe it's an SMD with a rather 'large' case.
  13. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Thanks ANTIFLASH for all the information. I just wanted to confirm which units you used for the rear and front turn signals. Also whether you thought their brightness was adiqute or not? I noticed there seems to be about three choices for the 7440 series. One being a super bright that looked interesting. Would that be overkill?
    Thanks again,
    Peter
  14. tino_ale
    tino_ale New Member
    Paris
    Interresting thread indeed but how do you adress thermal relief?
    The way I see it all these replacement "bulbs" are installed in lights and fixture that were not designed for LEDs. Unlike regular bulbs, LED need a good thermal relief in order to remain relatively cool (if they are too hot to touch you are likely exceeding their specs, making them inefficient and shortening their lifespan).
    Has anyone conducted some tests with a thermal probe in order to find out what kind of temperature your LED reach in steady state?
    You would be surprised how hot a low power device can get if there is very little thermal path to it's environnement.
  15. wildbottom
    wildbottom New Member
    99
  16. jsharpe
    jsharpe Member
    111
    26
    I forgot that there there was more than one lighting thread and made my last post, including some pictures to this one. The Cree SMD's are very small and easily mounted in the map, dome, and cargo, areas. I think the result ended up really cool. (pun intended) However, they are probably not for everyone. Even a single SMD is incredibly bright, substantially brighter than the stock or BlueVision bulbs and they are also more blue with a lower CRI.
  17. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    I went hard core in switching my trunk light to LED. The new light is on a tether so you can pull it out and light things up in front or outside. I did it on a gen II, but the Gen. III looks about the same.
  18. HI MPG
    789
    133
    93
    Orange County, CA
    So I was a bit irked that even after changing out all the interior lights to LEDs, those footwell and glovebox lights still have that amberish glow. In my endless search to replace these LED units (see post #91), I finally found, ordered, and installed the white bulbs, so now the interior is complete with full white LEDs. Once again my world can be at peace... j/k
    Attached are picts of the footwell. They were taken with different cameras, so the quality of picts will not be the same.
  19. nieveser
    nieveser Junior Member
    32
    Portland MI
    Great!! I am also trying to replace those LEDs for the glove box and the foot well!
    Where did you found them? Can you post the link?
  20. HI MPG
    789
    133
    93
    Orange County, CA
    Nieveser: For the footwell lights and glovebox light, you need to order from parts.com. The parts are based on a 2006 Lexus IS250. The part number is 81080-22040. They are approximately $11/piece.
    2 people like this.
