Interior Rattle! 2014 PiP
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Kurt Weiske, Feb 18, 2020.
  1. Kurt Weiske
    Kurt Weiske Active Member
    178
    131
    I've got a 2014 PiP and have an annoying rattle - it sounds like plastic on plastic, coming from the interior rear seat or trunk area. I can't find anything obviously loose, has anyone heard/fixed a problem with their Prius? If so, what was causing the rattle?
    52,390
    Just one? :p
  3. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    I found some large pliers and other various junk underneath the rear seat base, from previous owners and or inattentive mechanics. It just pulls out so worth checking.
    I find the rear spoiler can rattle on cold days too, or something around the tailgate. It's fine when it's warmer.
  4. Kurt Weiske
    178
    131
    Hmmm. I'll check the jack and the lug wrench under the driver's seat - thanks for the tip.
  5. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    Not to rattle you any further, these sounds will trick you into swearing they're in one place when they throw their sound from an unrelated location. I suggest you begin by emptying both glove boxes, the center console storage, door pockets and anywhere else you laid anything down. I'm betting the sound will clear up at that point.
