Intermittent A/C - no codes. needs Han Solo
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by tacopyro, Feb 21, 2021.
  1. tacopyro
    tacopyro Member
    87
    45
    Los Angeles
    Looking for a hint...
    My old - new to me 2012 Prius has had an intermittent A/C cooling since i got the engine and HV Batt running.
    The controls work fine, temp adjustment works fine. front and cabin temp sensor works fine. Rad Fans works fine. Compressor works fine. But i cant figure out when its going to work or not.
    Yesterday i drove it for an hour and it wouldnt cool at all. no Rad fan, no compressor noise. Engine never overheats. i had the cabin fan going full blast to keep the cabin cool while keeping out the dust. (73F ambient) Up until i hit a road bump fairly hard, then all of a sudden it started working and is still working.
    (just like Han Solo had to hit the falcon panel to get the hyper space drive working. in my old days it was the first rule of troubleshooting.)
    Since everything is working as they should. my conclusion is a loose connection somewhere. i checked the forum but havent come across a hint . does anybody know where it could be ? i want to make sure it doesnt loosen again anytime soon.
    also, i dont think its a corrosion problem at the compressor connector ...
  2. ChapmanF
    18,933
    My guess is you would only find hints around here if it were more common for people to develop intermittent faults in their A/C.
    As it is, from your description, your conclusion seems reasonable. Diagnosing for an intermittent loose connection is tedious, but the hints don't change much over the years. You fix yourself up with access to the wiring diagram (more info), figure out where the circuits are that could be involved, make a game plan for checking them (sometimes grabbing harnesses and connectors and shaking will give you clues), and follow the plan.
    Is there a specific reason you don't think it's a problem at the compressor connector?
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,011
    NJ-USA
    A copy of the service manual and Techstream software on an old windows laptop with a mini-VCI cable would help. First I would look the the diagnostic procedure to troubleshoot inoperative A/C - famaliarize yourself with how the system works. Then use Techstream to check all the ecu's for possible codes, and to look at relevant data - both when it is working and when it's not.
    It could be all kinds of things such as the high pressure sensor, or evaporator temperature sensor, etc. So you have to see what "good" data is on your car then you can recognize what is wrong when it doesn't work.
  4. tacopyro
    tacopyro Member
    87
    45
    Los Angeles
    Thanks Chapman. yes. and mr_guy_mann. during engine rebuild. the compressor connector and its area was relatively clean unlike the examples shown on the corrosion thread here. in any case i will take preventative steps soon.
    i do have the manuals and software and have read all the usual suspects and steps. but as you know, following it is tedious... was hoping to see if someone knows the quick fix...
    i guess i'll have to wait til it becomes intermittent again. so far its been working all the time now. will update if i do find it.
  5. ChapmanF
    18,933
    Intermittent issues come in all shapes, sizes, locations, and reasons, so there's generally not much reason to think there will be "the" quick fix. The one thing that is constant among such problems is the way you diagnose them: get out the wiring diagram and a meter, work along the circuit from one point to the next, test, shake, repeat. Find what's causing your issue in your car and then fix that.
    Usually, even if you do find a post that says "hey, I found the fix, totally solved the problem in my car!", it's just been posted by someone who had no reason to think about anything besides that one car's problem, and it's still not worth betting very much that your car's issue will turn out to have the exact same cause.
  6. WMcIntosh
    WMcIntosh Junior Member
    Orange County, CA
    2014 Prius v wagon
    I'm having the same issue with a 2014 Prius V. AC was cutting in and out for two days and then magically healed itself right after I dropped it off for my mechanic. Yesterday, my mechanic said he could find nothing wrong and couldn't diagnose it because he was "chasing a ghost." I'm pretty sure it's a bad sensor, but have no idea which one. I've read on Gen 1's and Gen 2's that you could hold down auto and recirc buttons and get a code? Is there a way to do this on gen 3's? A code would definitely be helpful here, but the check engine light has not been on when the ac was down. My only clue is that when the ac was blowing warm air, the compressor and fan would only come on for 1 or two seconds at a time...almost like a sensor or connection was loose. When blowing cold air, the fan would stay on much longer before cycling off and the compressor never seemed to go off, even after 2 hours of driving.
