intermittent buzzing noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Matthew J Anderson, Aug 5, 2019.
  1. Matthew J Anderson
    Matthew J Anderson New Member
    Rochester NY
    I am at a loss. I hear a buzzing noise intermittently, when the car is driving, when the car is off, and just sitting in the car sometimes. I don't know where it is coming from, or why?? Toyota claims they couldn't hear the buzzing noise when I brought it in for them to look at it. Any suggestions? IDK if I can attach a vid of the noise which I recorded on my tablet, but I'll try. If it sucessfully adds onto this thread, listen all the way towards the end, and you will hear the buzzing noise eventually.
  2. AzWxGuy
    AzWxGuy Weather Guy
    982
    496
    Tucson, AZ
    2021 Prius
    You are familiar with all the various normal noises a Prius makes? There is a periodic noise that it makes, usually only when it is on (made READY) and you press the brake pedal a couple three times. That is the power brake system pressurizing. It also does this when you first open the driver side door, preparing for use. You probably already know about this noise though. You say it makes the noise when the car is off, just sitting. Couldn't be some sort of vibration then. Hmm. Any non-stock electronics installed in the vehicle? Security system? Have you considered tinnitus?
