Intermittent Hi Temp Light
Discussion in 'Gen 3 Prius Main Forum' started by Stephen Auciello, Jul 23, 2022.
  1. Stephen Auciello
    Stephen Auciello New Member
    Hey folks greetings, I’m new in these here parts….have a 2012, hi temp light coming on occasionally, almost every time I get on highway, and only for a few moments. Seems to be connected (sometimes) to accelerating and/or going uphill, and usually when A/C is on. I did have the coolant level low for a while, in my negligence, but recently topped it off and (I think) bled out the air by running in maintenance mode for two fan cycles. Recently one of the times the light came on while driving on freeway, I stopped and popped the hood, but all seemed normal, fluid wasn’t overflowing or boiling and engine didn’t feel hot; got back in and light was off for the rest of my 10-15 minute trip.
    Any ideas??
    Thanks much for your time!!!
  2. JC91006
    16,923
    8,634
    How many miles on your car? One of the symptoms of loss coolant is a head gasket failure.
    You should try to bleed the air out of the system again and top off if needed
  3. ASRDogman
    ASRDogman Senior Member
    7,977
    4,050
    Also check the radiator. Make sure it's not blocked.
  4. PriusCamper
    PriusCamper Senior Member
    13,335
    5,395
    Pacific Northwest, USA
    Let us know if you hear air being sucked in when you open the coolant reservoir?
  5. Stephen Auciello
    About 165K (I’m out of town at moment)…that makes sense although for a long time quite simply i failed to monitor the coolant level….
    How to do that? It’s not the type that has a cap, as you’re probably aware….
    I’ll check for that next, thanks!
    #5 Stephen Auciello, Jul 24, 2022
  6. ASRDogman
    7,977
    4,050
    The radiator, and ac condensor. Make sure the fins are not clogged with dirt, branches, etc.
  7. Noahdoge
    Noahdoge Active Member
    219
    148
    Mississippi
    Sounds like you might need to replace the ICE water pump. They are known to start sticking and not work properly at high mileage. It’s expensive to get done at the dealership but you can buy oem from Toyota parts online for $200 and do yourself or have your mechanic do it. You will also need 2 gallons of Toyota oem antifreeze as well. Good opportunity to do the inverter coolants as well. Definitely clean your egr system with your mileage if it hasn’t been done before. Refer to @Mendel Leisk signature on that.
    Foxglove likes this.
  8. Stephen Auciello
    I did notice air sucked in when opened reservoir cap……checked right after I parked so engine was warm, not sure if that matters ….
  9. Stephen Auciello
    Got it, I thought you meant clogged inside…
  10. Stephen Auciello
    So that’s what I was thinking as well and was ready to do, but the light is not super erratic, but consistently coming on usually within a few minutes of starting to drive, and then turning off and staying off…
  11. ASRDogman
    7,977
    4,050
    If you search ebay, you can find just the impellor. About $40.
    That's what I did with mine...
  12. Stephen Auciello
    Nice thanks!
  13. PriusCamper
    13,335
    5,395
    That sucking sound when you open the reservoir lid means you're losing coolant. Usually this combined with engine misfire codes is confirmation for blown head gasket, but in your case it might only mean a leak related to overheating/pump failure.
