Intermittent Issues with Starting/Battery 2007
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cwt, Sep 1, 2023.
  1. cwt
    cwt Junior Member
    Davis, CA
    My car will sometimes be completely dead. Other times, I can start the car and it will either have been ok while off or will show evidence of having no voltage at sometime since I drove it (lost presets, on-screen info for miles and mph zeroed out). Consistent with this, there have been times that the car would not start, I drove my backup car, and later - sometimes days later, the car will start right up. My band-aid solution is a portable charger, all I have to do is connect the charger to the charging points and it starts right up. However, about half of the time it starts, it goes into accessory mode automatically without me even entering the car. My neighbor knocked on my door the other day as my wipers were on (I must have bumped the wiper arm when getting out after the car wouldn't start). This last time, I was finally able to get my voltmeter on the battery and measured 0.9V. (I would like to have words with whoever designed the way to open the hatch without car having power, but I digress)
    I did replace the 12V battery and the problem continued. I took the battery to the auto store who confirmed it was functioning correctly (showed the correct amount of CCA under test).
    I suspect a short, but that does not explain how the battery is recharging without running. Also, I have seen it go from functioning to non-functioning without moving, so I am doubtful about a loose wire. Does the hybrid battery charge the 12V while the car is off?
  2. dolj
    dolj Senior Member
    8,655
    4,406
    Wellington, New Zealand
    The battery is not recharging.
    Where did you measure the 0.9 V reading? Actually at the battery probing the terminals? Or just touching the probes to the clamps?
    Have you checked that the battery terminal clamps are fully seated at the bottom of the terminal posts and are clean and tight?
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Given your reported symptoms, this is almost always caused by a bad connection.......
    at the OTHER end of one of the main battery cables.
    The negative one where it connects to the body/frame is the usual culprit.
    Tombukt2 likes this.
  4. cwt
    cwt Junior Member
    Davis, CA
    Measured at the battery. The weirdness continues, however. I removed the cable from the negative battery terminal and waited a day. The battery came up to over 12V. I don't see how this is possible since there is no completed circuit. I am also now fully convinced that the car is going into accessory mode at some point while the car is parked which is why the battery is being drained. I also think that at some point, the car after discharging the battery resets and drops out of accessory mode and the hybrid battery recharges the 12V while the car is sitting there. I did have the control board changed out do to the recall about 10 years ago when the dash went dark, but it has been staple up until now....
  5. bisco
    52,891
    the hybrid battery is disconnected from the car by relays when off. it is not charging the 12v.
    since you already installed a new, known good, 12v, why do you say it came back up over 12 volts?
    wasn't the old, bad battery the one reading .9v?
    what do you mean the circuit isn't completed?
    i onder if you have a faulty power button
