intermittent misfire cylinder 1 code
Discussion in 'Gen 2 Prius Technical Discussion' started by Clark Griswold, Jan 10, 2013.
  1. Clark Griswold
    Clark Griswold New Member
    29
    Bolingbrook, il
    I posted this problem several months ago about a p301 code that my 2007 Prius has been generating. I eliminated all the easy stuff... plug, spark unit, fuel injector. Over the past year since I've had the car, the CEL light has gone on for a couple months then shut itself off for a couple, then back on ... probably has shut itself off 3 times in the past year, each time staying off about a month or two before coming back on. Some background on the car, supposedly the PO hit a rock and damaged the motor about 2 years ago and had the short block replaced.
    Anyway, the CEL has been on again for about a month, and I got a notice for Illinois emission testing, so I decided to take it in to the dealer and have him do a diagnostic so I can get the emissions passed. After an hour and a half of testing they told me that the best they could ascertain, the car has been submerged in water, as there is a lot of rust in areas that never get any rust, and they think there's a short somewhere. The service manager at the dealership I go to is a really good guy, honest and very helpful (hard to believe huh?) and he said if it was his car he wouldn't spend the money for another 5 hours of trouble shooting, and if the car runs good he'd just drive it as is. They cleared the CEL and the service manager just charged me for an oil change as they caught a recall on the steering that hadn't been done and figured he'd let me slide on the hundred for the diagnostic.
    As I previously mentioned, this problem is intermittent, the car runs well even when the light is on and my mileage is still in the mid to upper 40's (most of my driving lately has been short 2 or 3 mile trips), and I've kind of learned to live with the light on. I guess under the circumstances it's better than dropping five hundred to a thousand bucks on the problem. As far as the emissions, after leaving the dealer I drove about 15 miles to the emissions testing station and cycled the car on and off a couple times on the way over there, and it passed, so I'm good for 2 years. I just thought I'd run this additional information past you all and see if it strikes a note with anyone. I would still like to get to the bottom of the problem instead of ignoring it, as long as it doesn't end up costing me a thousand or two to do so.
  2. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    There was a long running story with a Prius missing on cylinder one, turned out to be the injector after much work.
  3. Britprius
    5,194
    1,924
    Search "misfire cylinder one during warm up".
  4. Clark Griswold
    29
    Bolingbrook, il
    The injector has been changed and I swapped igniters between 1 and 2 cyls... like I mentioned I eliminated all the easy stuff already.
  5. Clark Griswold
    29
    Bolingbrook, il
    Very interesting thread Brit. I did change the injector but haven't done a leak down test or sprayed carb cleaner around the manifold and injector to check for leaks. Just curious... how is a compression and or leak down test done on a prius? Not like you can crank it over or anything.
  6. Patrick Wong
    18,213
    6,529
    The leak down test is performed the same as on any car. Just turn the crankshaft pulley center bolt with a socket wrench to position each cylinder to TDC, one at a time.
    The compression test would require the Toyota diagnostic laptop to get MG1 to spin the engine.
  7. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    You said you did the easy stuff already which included swapping the injector and the spark igniters (btw, why do we call them "spark igniters" here but they are 'ignition coils' every where else?) but did you change the spark plugs?
    I also remember reading about leaking intake manifolds causing misfire DTC's and thats why you need to rule that out too.
  8. Patrick Wong
    18,213
    6,529
    The Toyota repair manual calls those parts "ignition coils". So you can use either name.
    PriusGuy32 likes this.
  9. PriusGuy32
    1,417
    514
    Ive never heard them called "spark igniters" until I came to PC but we are a unique group of people so I accepted it for what it was :D
    I reserve the right to call them ignition coils at my discretion and take pride that even the Toyota repair manual disagrees with the PriusChat forum vernacular!
  10. Clark Griswold
    29
    Bolingbrook, il
    I did change all the plugs and then swapped 1&2 after the problem persisted just to make sure the new plug wasn't bad. I will spray some carb cleaner around the intake manifold... forgot to do that one... thanks.
  11. dgpgramma
    dgpgramma Junior Member
    TN
    I have a 2008 Prius and have had a long running problem with P301 code. It has been to an independent mechanic and the Toyota dealership. Plugs, coils, injectors, compression tests, it has all been done. Finally, Toyota dealership convinced me it was ECU and I parted with 936.00 dollars. Four weeks later, P301 is back! Toyota expert took pictures of diagnostic that was run and sent it somewhere. They said check injectors and do compression test. It has already had 2 compression tests and I don't know how many times injectors have been out. It would appear there is NO fix to this problem.
  12. valde3
    valde3 Senior Member
    2,002
    751
    Finland
    There’s no problem (in cars) that couldn’t be fixed (to as good as new). Unfortunately sometimes it’s not feasible, but still…
    After plugs, coils, injectors, mechanical, and ECU are ruled out it pretty much has to be wiring. Unfortunately many shops seem to be rubbish at finding problems in wiring. Good shop should check the wiring carefully before going for ECU.
  13. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    The injectors clogging up is a very common problem on hybrids since they stop firing on a hot engine quite often and create carbon deposits on the ends. Now you mentioned you changed plugs and swapped ignition coils but what exactly did you do with the actual injector? Was it changed and did you use a new OEM part?
    I would also suggest to run a full can of Seafoam through 1/2 tank of gas then run a 2nd can in a full tank. That will eliminate water in the fuel and help to clean any injectors which might have issues with deposits as well.
  14. oil_burner
    oil_burner Active Member
    249
    126
    it sounds like a grounding issue with your car, especially if it has been flooded and submerged. Make sure the engine and chassis grounds are not corroded. Find each one and unbolt, take a wire brush and clean the metal, there must be bare metal underneath. Smear a dab of dielectric grease and tighten. Also check the wiring harness for damage or shorts. Since newer cars use coil on plugs, the wiring loom leading up to the coil is low voltage and easy to repair.
  15. bacire
    bacire Junior Member
    MA
    Had the same misfire on cylinder 1 (P301) before and after ignition coil replacement, all 4 fuel injectors, and the EGR valve replaced (under enhanced service warranty from Toyota). $2,000 later the dealership suggested I just replace the entire engine with a salvage ($4,600) since the mileage is at 138,000. I notified Toyota of the situation and informed them that many people on the Prius Chat were experiencing the same issue. As suggested, I notified Toyota but there was nothing they could do since there are no warranties available given the mileage and no enhanced warranty because of a "known issue". I expressed DISAPPOINTMENT because I purchased a Toyota for their Quality reputation and expected it to last longer than American cars. I owned a Dodge Dynasty back in the day and it has 165,000 miles on it before having trouble with a rod.
  16. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Misfires are often engine damage especially misfires that continually move around from cyl to cyl caused by running the engine so low on oil it throws a check engine light or master caution triangle.
    Running low on oil in this engine usually damages the piston wrist pin bearing causing slop of the piston in the bore that causes vibration in main bearing and that bottom end vibration distorts the cam and camshaft fg & pg waveforms and the engine ecu can not decode this and sees tht as loss of expected power and throws a misfire.
    Seen hundreds of destrgoyed motors on this forum from very poor oil maintenance.
    It’s such a reliable car people rarely open the hood apparently.
    That’s unfortunate because if it’s a 100000+ mile motor it most likely eats oil so you consistently run the engine with very low oil if you do not regularly check it.
    This situation is greatly exacerbated if you have the car oil change done at the dealer who use terrible oil and will never inform you that you rolled in with no oil in the crankcase. Do you never know you own an oil eating little monster.
    If I had consistent misfires after much work I would put the car up on blocks and put the car in inspection mode and with the car Engine running continuously in inspection mode listen very carefully under the engine for vibration.
    Engine damage starts with misfires. Then becomes knocking then if continued to drive the #2 piston likes to fly out the side of the block.
    Seen that many many times here.
    Check your oil every saturday before starting the car. More frequently if you notice any oil loss.
    Keep the oil right at the full line,
    bshef likes this.
  17. MTL_hihy
    536
    261
    Maritimes, Canada
    I wouldn't jump to conclusions right away that engine misfire is always major mechanical issues unless you've already ruled out the simpler fixes already.
    bshef likes this.
  18. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Who said always.
    Not a conclusion but a possible cause.
    bshef likes this.
  19. bacire
    MA
    What simpler fixes are you referring? I am still in line to have the engine replaced but can try some other options. Someone informed me that it could be a sensor or computer issue. I did notice the coolant reservoir running a little low. Can I purchase the 'pink' solution anywhere as long as it is pink (ie:Walmart)
    Note: compression test was good and cylinder leak down test found traces of coolant in cylinder 1, most likely caused by head gasket leak - per dealer. They recommended tearing down the engine to confirm (sounds costly to me).
    #19 bacire, Nov 5, 2018
  20. bacire
    MA
    Also saw something about testing the EDC DME before replacing sensors+labor. Cost ~95.00
