intermittent misfire cylinder 1 code
Discussion in 'Gen 2 Prius Technical Discussion' started by Clark Griswold, Jan 10, 2013.
  1. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Coolant loss and coolant in the cylinder. Sound like a head or head gasket. If you take the radiator cap off the radiator and run the engine do you see bubbles? Do you see white smoke when you first start the car in the morning?
  2. bacire
    bacire Junior Member
    MA
    No smoke of any kind noticed and the problem/shuttering when the engine starts does not happen everyday. On bad days it happens in the am and after work when starting the car.
