Intermittent preignition knock / pinging
Discussion in 'Gen 2 Prius Technical Discussion' started by MobilePrius, Mar 21, 2022.
  1. MobilePrius
    MobilePrius Junior Member
    Mobile, AL
    Hey all, I recently got a 2007 Prius from my dad that has 275k miles and a newer battery. So far I’ve loved this vehicle - my second hybrid since having a 2001 Insight many years ago!
    Since getting it a few weeks ago, I’ve noticed that the engine has VERY bad preignition knock, but not all the time. It doesn’t occur when the engine is cold, only warm, and it tends to only occur during low- or mid-throttle, rarely when under full throttle. I saw this thread, but it was for Gen 3, and EGR isn’t a factor here.
    The engine has always had fresh full synthetic oil (uses 1qt every 3k miles) changed every 5k, and had the PCV valve replaced a year ago. I’ve already run two full fresh tanks of top-tier grade 93 octane and a can of Seafoam, but the pinging remains and is just as bad as on regular 87 octane.
    I live in a very hot and humid climate, so pinging isn’t new to me - every single vehicle I’ve owned has had it to at least a minor extent, including a 2019 Accent. But this is the absolute worst I’ve heard. I’ll post up a video if needed to confirm it’s what it sounds like to me. In any case, my dad is a bit hard of hearing, but he has confirmed he’s heard this noise with the engine during the time he’s owned it, which has been a few years now. I’m worried about doing permanent damage, but since it’s been this bad for years now and nothing has come of it so far, I’m wondering if it’s not a big deal? The internet has always made preignition knock out to be a swift and fatal thing, but that’s never been my experience. I’m just afraid here because it literally sounds like a bag of rocks and metal being violently shook.
  2. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
    When were the plugs last changed? Every 100k to 120k miles is the recommendation. Were they OEM from dealer or an Amazon counterfeit? Also maybe one of the coils. Have they ever been changed? At 275k miles. Things start to need replacement. Plug wires?
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,097
    6,963
    Texas Hill Country
    Generally higher octane gas will resolve pinging and should be used because preignition is bad and ultimately could blow a head gasket, burn valves or worse. Try Exxon. Often it is excessive carbon buildup in the cylinder that is responsible for hot spots and increased compression. Nothing will get rid of the carbon other than a teardown. On a Prius, pinging can temporarily go away when the hybrid battery is fully charged because the battery is taking some of the load but returns under lower battery voltages.
    #3 rjparker, Mar 23, 2022
  4. MobilePrius
    Mobile, AL
    Plugs were changed around 250k with NGK 5464 iridium at the time, wires were not changed. Records show the last owner replaced plugs through a dealership at 175k and 90k back in the day. Unsure of the coils.
    That’s exactly what I’ve noticed as well - when the battery is lower and the engine has to do more work, the pinging is louder than the normal engine sound itself. The fuel is from Costco, but I have an Exxon local that gets frequented that I can try for the next couple tanks
  5. rjparker
    11,097
    6,963
    Texas Hill Country
    Using a laser to remove carbon.
    From Gasketmasters youtube short.
    #5 rjparker, Mar 23, 2022
  6. JahT
    JahT Member
    145
    77
    In my general experience in other cars "pinging", as in preignition, occurs under load meaning more of a full throttle, but you say it happens at low to mid throttle. Are you sure it is preignition and not just the engine rattling due to misfires? Do you have any Check Engine Light codes?
  7. rjparker
    11,097
    6,963
    Texas Hill Country
    A Prius is unlike other cars in that it runs a 13/1 compression ratio using regular. It depends on Atkinson Cycle valve timing and battery assist along with a knock sensor to minimize pinging. I have seen the exact same low speed pinging on a carboned up Prius. High battery charge, high octane or, worse case, mechanically cleaning out the carbon resolves it.
    What Is the Atkinson Combustion Cycle, and What Are Its Benefits?
    JahT likes this.
  8. MobilePrius
    Mobile, AL
    No CEL codes at present or stored in history. I certainly think it's preignition simply because it sounds identical to what I've experienced with others cars during the summer heat on 87 octane, just amplified and occurring at much lower throttle. Here's the best clip I've managed to get on my dash cam of the sound:
  9. Another
    1,819
    520
    Naples, Florida
  10. MobilePrius
    Mobile, AL
    Replaced just last year as I understand it. It’s what I thought of as well, but already asked if my dad changed it out while he had it and confirmed it got done sometime a year ago.
  11. MobilePrius
    Mobile, AL
    Alright, ran through three full tanks of Exxon 93 octane, and surprisingly it hasn’t made one iota of difference - knocks just as bad as it did on 87.
    Considering everything previously mentioned except spark plug wires have been replaced, is there anywhere else I should look, or could the wires alone be a culprit? Is it safe to continue driving as-is? Again, it’s been doing this for years without getting any worse (or better), what throws me off is just how severe it is and the fact it’s intermittent - you can literally hear the profile change when you go above 75% to compensate for the knock, like it loses some relative power but completely clears up all knock until you drop down in throttle, and only occurs when the engine is fully warmed up on warmish days (didn’t do it during the couple of cold snaps we’ve had as spring has settled in)
  12. Another
    1,819
    520
    Naples, Florida
  13. ChapmanF
    19,019
    The key magic feature of the Atkinson design is making the compression ratio and expansion ratio not be the same.
    The original Atkinson design did that with a really weird connecting rod and crank setup; Prius does it just by keeping the intake valves open late, so the upstroke doesn't turn into a 'compression' stroke until the piston is already part-way up.
    The result is the Prius has an expansion ratio of 13:1, but its compression ratio is nowhere near that. If it were, and running on regular, that would be disastrous. Its compression ratio is much more like what a conventional engine running on regular would have.
    While it does have a knock sensor so it can try to find the optimal spark timing without going too far, that's not a Prius-specific feature; conventional engines have that too.
  14. MobilePrius
    Mobile, AL
    Oh yeah, this was already mentioned! Nope, not replaced yet, so I’ll make that the next order of business
  15. MobilePrius
    Mobile, AL
    Coils replaced, ran two more tanks of premium gas, and still no change. Is it possible the knock sensor is just not working at all anymore?
  16. rjparker
    11,097
    6,963
    Texas Hill Country
    It can be a hv battery going lower than expected along with high carbon buildup in the cylinders. Not enough battery assistance and increased compression. Knock sensors don't work instantaneously. Been there done that.
  17. Another
    1,819
    520
    Naples, Florida
  18. MobilePrius
    Mobile, AL
    Banking on high carbon buildup given the mileage. HV battery was replaced new (not refurb) just a couple years ago and pulls good and strong when charged, but I sometimes have to sit parked with the A/C running for a few mins, and taking off with two bars makes the pinging literally sound like rocks and metal shavings in a blender.
    I’ll look into what it’ll take to get the carbon addressed - never had it done before and no idea the cost.
  19. rjparker
    11,097
    6,963
    Texas Hill Country
    The only right way to do it is a head gasket job that includes a machine shop rebuild of the head. This would be thousands. There are no effective "in a can" chemical methods once its bad regardless of marketing. If the cause is only carbon on the back of the valves, walnut blasting is possible but that method is also expensive. This kind of cleaning is more common for direct injection (gdi) engines and is usually not an issue on our cleaner port injection engines. Walnut blasting solves an issue where gdi valves are so carboned up they are not sealing well. More advanced gdi engines are now being supplemented with port injection.
    I think I would try several more tanks of 93 octane from Exxon, Shell or Chevron before going further. Especially if you have a new Toyota battery and not a refurbished one. Several vendors claim to be new but are really used modules which quickly get weak again.
    MobilePrius likes this.
  20. MobilePrius
    Mobile, AL
    This was in fact the way! Reviving this simply to say that after going through twelve tanks of 93 octane from Exxon, the pinging has FINALLY abated. The only way you can get it to do it even a tiny bit now is if the battery is at 2 bars and you're trying to pull onto an interstate on an uphill onramp on a hot summer day at full throttle. Otherwise, it's as quiet as it should be. I did try some mid-grade 89 octane on one tank a few weeks back, but it immediately went back to terrible. Seems this Prius is just gonna be a high-octane machine from here on out.
