Intermittent red triangle and heat without check engine light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jama707, Oct 16, 2022.
  1. Jama707
    Jama707 Junior Member
    SACRAMENTO, CA
    Prius 2007 @ 198k.
    I’m getting intermittent red triangle with beep and also heat blows hot intermittently. And there’s also high temp warning on MFD. But no check engine light - no engine noise or knock.
    My brother overfilled the oil and drove with it - I’ve just replaced it and it’s now within the normal level.
    Its 12v was replaced a few months ago. And the inverter coolant have turbulence.
    The coolant overfill was almost empty added some more coolant.
    Im not sure what could be the problem. Is there way I could pressure test the coolant system? Or any other tests?
    #1 Jama707, Oct 16, 2022
  2. JC91006
    16,827
    8,600
    You should actually check the coolant at the radiator, not the overfill/reservoir. The radiator cap is under the front engine cover
    Jama707 likes this.
  3. Tombukt2
    Tombukt2 Senior Member
    13,416
    2,415
    Durham NC
    Inverter pump
  4. ChapmanF
    18,546
    And while you can check in the overflow bottle any time (it's not pressurized), do not loosen the radiator cap except when the engine is fully cooled down.
  5. Jama707
    SACRAMENTO, CA
    Close off the loop - it didn’t notice it was missing serpentine belt. I don’t know how I missed it. After $28 OEM serpentine belt it runs fine.
    Tombukt2 likes this.
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,088
    1,997
    NJ-USA
    Good find! Might want to just replace the pulley for the belt- it's probably original and might not go too much longer.
    Jama707 likes this.
