Intermittent red triangle and problem message on MFD
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DocDNA, Nov 23, 2019.
  1. Aldi
    Aldi New Member
    Salinas
    My 2008 Prius gets RTOD sometimes when I go faster than 60 mph and then other times I can drive 80 mph, but only after the car has been driven before during that day. What's up with that?
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Welcome, Aldi.
    You'll need to read the codes and find out. A good code reader will show you code histories even if the code isn't current and the light went out. We have lots of threads here about code readers.
    Once you have the codes, come on back and any of several of these Prius savants will be ably to tell you what it or they mean. These folks know there stuff, but all the triangle tells you is that something's wrong. Sometimes you can guess it given the circumstances but often not.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,100
    Columbia, SC
    one thing that immediately pops into my mind would be engine or inverter cooling system temperatures.
    jerrymildred likes this.
